No. 25 Cable Control Oil Level
DavidG
Send a private message to DavidG
I have a D6b with a #25 cable control, but don't know how to check the oil level in the control unit. Is there a plug on the side? Do you just fill up the tube to the top? And what type of oil is correct? 90 weight EP? Thanks for your help.
Tue, Feb 9, 2016 9:31 AM
That's correct, late model units just fill the stand pipe on the LH side.
SAE90 wt
Tue, Feb 9, 2016 10:28 AM
JoeG
Send a private message to JoeG
SAE90 wt
My 25 has a plug on the RH side for the level check and a filler plug between the fairlead sheaves, basically right between the drums.
Tue, Feb 9, 2016 6:46 PM
