No. 24 CCU Clutch Adjustment
Calldies
Send a private message to Calldies
Hello. New to the site. I have a D7-3T with a front CCU. Last Summer I installed a new brake band and parked the machine for the Winter. I did an electric start conversion on it this week. When I started it, the blade went up and broke the cable. In a nutshell, I think I forgot to tighten the center shaft clamp when I installed the new brake. Would this most likely be the problem? How do I correct this problem and readjust clutch? Lastly, I do have the "pony motor" for sale along with the clutch, linkage, etc. Also, I am looking for a new cutting edge for the 10' blade (92" edge and end bits). I can get them directly from Cat. Is there a better source?
Wed, May 19, 2010 8:43 AM
bruce oz
Thank you received: 21
http://s315.photobucket.com/albums/ll477/bacoly/cat%20ccu/
hello Calldies,ccu manual above ,bruce oz
Wed, May 19, 2010 9:06 AM
Thank you received: 39
Reply to bruce oz:
Hi, and welcome.
We just had a discussion on that topic a few days ago:
Depends on the unit serial number, early ones could tighten, later ones would loosen.
http://www.acmocbb.org/ACMOC_BB/showthread.php?9210-24-cable-control-problem
Here are the instructions on adjustment:
Yes, the pictures are out of order, don't know why, they were loaded sequentially.
Wed, May 19, 2010 9:19 AM
Calldies
Reply to bruce oz:
Thanks Bruce for the quick reply. This is exactly what I needed!
Wed, May 19, 2010 9:25 AM
Calldies
Reply to Calldies:
Thanks Old Magnet. These photos look like my ccu. Sure glad I "stumbled" across this site and found you guys.
Wed, May 19, 2010 9:37 AM
