No 12 Grader Flywheel
Walker
Send a private message to Walker
Hello Good People!  I have what I believe to be a 1956 No.12 Grader (80C475) with a D318 and a wet clutch and electric start. A year or two ago part of the flywheel gear decided to give up the ghost. I pulled the starter and saw the damaged flywheel teeth preventing the starter from engaging and I have been having to pull it to start it since then.  The machine runs great otherwise so I would like to replace the flywheel assembly and/or the gear. I am not pulling it apart until I can find a replacement part to fix it so I don't know exactly what I will be looking at once I get in there, but I know for certain the gear teeth are damaged.  Which leads me to my question, does anyone know where a guy might be able to source a flywheel?   After digging the through the parts manuals in the library, which is an awesome resource by the way, I THINK the part i am looking for is either 5H42 flywheel assembly or a 786253 gear. I am just not having any luck finding one online.  Any possible leads would be much appreciated.
Walker
Sun, Jan 28, 2024 1:08 AM
rax200
If you lookon the website Machinery Trader and punch in the number 5H0042 there is some there.
If you see a part number 5h42 yo must make it to a min if 6 digits foe example,
5h42 - 5h0042
S1594 - 0S1594
S509 - 0S0509
Regards
Sun, Jan 28, 2024 2:52 AM
Thank you received: 20
Reply to rax200:
5h42 - 5h0042
S1594 - 0S1594
S509 - 0S0509
Regards
Look for 5H0042 flywheel and 7B6253 Gear
Sun, Jan 28, 2024 3:32 AM
Walker
Thank y'all very much!
Sun, Jan 28, 2024 6:47 AM
Thank you received: 91
Reply to Walker:
Would you need to replace the flywheel or is the ring gear replaceable, heated to install and driven off to remove?
Might it be a good idea to ensure the pinion on the starter is also in good shape so you do not damage the replaced flywheel/ring gear assembly.
cts
Sun, Jan 28, 2024 9:09 AM
Dandy Dave
Send a private message to Dandy Dave
Reply to ctsnowfighter:
cts
Your Grader is a 1957 Model year. D-318 with 115 HP Direct Electric Start from the factory. Produced from 1955-1967.Weighs approx. 22,000 LBS.
Sun, Jan 28, 2024 8:36 PM
