No. 12 D318 fuel injector removal
Delta KJ
I have a No. 12 grader (80C) with a 24 volt direct start D318 engine.  The engine has glow plugs and the fuel injectors do not have the typical hex nuts securing the injectors.  Can someone coach me on how to remove the injectors?  If there is special tool required can someone describe it to me?
Thank you.
Thu, Sep 29, 2022 12:12 AM
Thank you received: 50
Takes one of these to remove the splined retaining nut...
https://www.ebay.com/itm/402071140754?hash=item5d9d4eb992:g:qKoAAOSw3a9jI3lQ&amdata=enc%3AAQAHAAAA0OwwPAO5QjeegPLFzxnwD9IGLGYxkH7bArOCzizqIHgPvI%2BC3Z%2BacE4MVIJZwkF3aZ%2BIna5meTMSXVMp81NfYq9LqNaV%2BdRdp9eECmlXhCpKT2RymnMhf9WHvMoRe812r6MJ8IG20JaL4i5WjS0tSR9TE%2FgypOjY6Vr996B24fpOS2hyvrRcA4dE7S2XfQELefIgshTxugxm%2FSabpjXaHAsFXPMylyrsOfbSFWf1tffQRIkHo1L%2BfW5hUeFQIU2ouNo6bEa0wa9h555clB0NcE0%3D%7Ctkp%3ABFBM1ujn0fBg
Thu, Sep 29, 2022 12:23 AM
Delta KJ
Thanks... That's what I needed to know!
Thu, Sep 29, 2022 3:23 AM
