NEXT step on D7E, Help needed
Showing 1 to 9 of 9 results
tacacat
Send a private message to tacacat
Hello all,
My next adventure will be to fix the mis-alignment of my rt. track rail , I purchased machine as is , broken clamp bolt on forward side of rail clamp to final hub, threads all worm out , drilled and put a CAT Heli-coil in , but as seen in pic , rail is still being pushed back , 0 clearance on front and 1/2 inch in rear .( not sure this is norm ,other side not as tight) center sway bar/balance, seems straight ,but( rt. side ) also has 0 clearance toward front ,where as left side is equal distance. any thoughts greatly appreceated- I've not had to deal with this problem before- so I'm in New-be territory here
Pic 1,2 show rt. side where clamp sits
pic 3,4 show center support rt. side > left
pic 4,5 lt. side vs rt. side
pic 6 is rear stabilizer-have not had this apart yet to see if bushing is good ?
Thanks Tim
Fri, Nov 16, 2012 11:14 PM
Thank you received: 52
The "0" clearance at the front and "1/2" clearance at the back of the clamp and saddle is probably lost metal due to running without repair. It's going to be tough to bring back to original dimensions, but that is what is required to fix.
The diagonal brace bearing should also be checked as well as the outer support bearing (between the bearing cage and the support) as running without the outer clamping puts these bearings in a bind.
Sat, Nov 17, 2012 12:17 AM
tctractors
tacacat, on the inside of the top clamp is there a slot location for a key in the joint area??? if so reverse the tractor sprocket onto a baulk of timber so the hub will be free from the frame, then turn the hub using the end cover bolts to bring the key into the correct location.
tctractors
Sat, Nov 17, 2012 3:23 AM
catsilver
This machine has been run with the clamp bolts loose or broken and the bore in the bearing carrier and track frame bore has worn. allowing the track frame to 'toe out' at the front and the track to run out of line, The onlyway is to replace that support bearing, build up and re-bore the track frame and cap and re-bore them, You will also find the bronze bush inside the support carrier is worn, also the actual bearing hub on the dead shaft. Quite a lot of work to do but its the only way to get the track lined up again.The main cause of this is lack of use of the grease gun to lube both inner and outer track frame pivot bearings.
Reply to catsilver:
Think I'd be looking for a parts tractor with a good used track truck.
Sun, Nov 18, 2012 7:06 AM
Wombat
Donor
I am with you tctractors, the hub needs turning.
Sun, Nov 18, 2012 8:08 AM
Reply to Wombat:
I can see where the outer bearing assembly (#7) could be rotated but I can't find any indication that there is a key alignment involved from the literature I have.
Does show that the grease zerk should be at the top which it isn't on this unit.
Anybody got a picture of that feature?
Sun, Nov 18, 2012 9:38 AM
Thank you received: 35
my OMI shows the zerk in the outer bearing to be at the bottom.
When aligned to the bottom the grease enters in the loaded area.
We used to fit them this way. Simply rotated the zerk to the lower position before torquing the clamp.
As for the gap in the cradle I would jack the machine up a bit, to get a gap between the holder and the track, frame and check for rust etc under the outer bearing holder and the frame seating area.
Cannot recall if there is a key for the bearing holder on the D7E, but I feel the holder is simply clamped in position--this will be evident by a gap at each side of the clamp to track frame clamping faces when the clamp is torqued up.
I stand to be corrected as it is too long ago now since I worked on undercarriage. I do not have any literature for this late of a machine to double check.
Sun, Nov 18, 2012 10:02 AM
Reply to edb:
Hi edb,
Interesting that 48A1 started out with zerk at the bottom. At 48A1136 it moved to the top along with a different bearing cage holder that has a drilled pasage for the grease. So it would seem a definite indexing is required to receive proper lube.
This unit had been run with a stripped out clamping bolt so I doubt if rust/crud in the support area would be a problem and if it even had any type key indexing it is probably long gone.
Correction:
The drilled passage is in the outer bearing support, not the bearing cage holder.
Sun, Nov 18, 2012 11:20 AM
tacacat
Hi edb,
Correction:
Thank you all for the replies, I've got some time this week to investigate deeper/ re-align things , and think this one through. Knowing all this now I would not have purchased this machine, seems the previous owners just pushed dirt and had no desire to maintain .
Mon, Nov 19, 2012 9:02 PM
