the brake on one side has come apart, we think and let chunks of junk go through the system. Told when we purchased it that the brake had just backed of and wouldn't stay snug. 😞 live and learn
Check under the floor deck on the RH side ( square deck plate w/ 4 bolts, underneath a filter canister w/ 6 bolts) if it's a 36a Cat moved the trans filters up to the RH side of the engine on the 46a, not sure what year
Thanks we will take a look. We found the stacked filters at right hand rear of the engine beside the engine filters. But this other filter has us stumped. It is a smaller filter. We have a 46A 16248
Finng Cat probably gave you a final drive filter . Its about 3" in dia ,and about 8"to 10" long. Each final drive has its own filter accesseed by removing a small cover at the back of the tractor main case, up top on the right and left sides .each final drive have a pump mounted in them that pumps oil up to the filter and to the bearings internally for each final drive .Remove 2 3/8's bolts ,and pull the cover ,and filter out of rear main case
What's the part number on the filter element?
46A11264 to 46A23357 used a single element filter (fairly large)
46A23358-up used two smaller elements. You may have one of those?
Might be final drive filter? Why don't you call cat and ask what filter is for? Did you clean your transmission pump screen?
Good luck
Bob
[quote="bluox"]Might be final drive filter? Why don't you call cat and ask what filter is for? Did you clean your transmission pump screen?
Good luck
Bob[/quote]
Not sure Bob we cleaned two magnetic screens. Some one put a piece of steel in way of the access on the skid plate. So we are having a hard time trying to find all the screens etc.
