New track chain for D6 9U?
LeakyBoot
Send a private message to LeakyBoot
Can these still be purchased? Thanks,,,, LB
Mon, Mar 5, 2018 9:33 PM
7upuller
LeakyBoot,
Yes... I put a D5 set of tracks on my D6-9u. I put sprockets on to match.
Mon, Mar 5, 2018 9:46 PM
catsilver
Reply to 7upuller:
LeakyBoot,
No need to change sprockets if you don't want to, suitable chains will still be available.
Tue, Mar 6, 2018 12:06 AM
Thank you received: 46
Reply to catsilver:
39 section chain is part #2S7577
40 section chain is part #2S7579
Both are 6.75" pitch with 5/8 pad bolting and both are considered non-current production.
Most get converted to D5 chain which is 6.91" pitch and need sprocket rim change to match.
Tue, Mar 6, 2018 12:35 AM
Here ya go.
https://toledo.craigslist.org/hvo/d/caterpillar-d6/6501599771.html
Tue, Mar 6, 2018 3:27 AM
JackD6-5R
39 VS 40 link ,my parts book only shows 39 link chain. Is the 40 for newer machine or different size idler? Looked at 9U the other day has 40 link , chain looks good the pins &bushings look good but idler set way ahead too far ahead, maybe wrong chain.
Tue, Mar 6, 2018 9:13 AM
Reply to JackD6-5R:
40 link would be correct 6.75" pitch chain with large front idler.
Ones less link if using 6.91" pitch chain.
Tue, Mar 6, 2018 9:19 AM
LeakyBoot
Did just get a quote on new and is 1800 per chain. Thanks for replies. LB
Tue, Mar 6, 2018 10:06 AM
Reply to LeakyBoot:
Cat not after market?
In some conditions I have been told Berco was better(sand),but no good in rock(chip from shock). But that was 30 years ago(time flies) when made in Italy.
Wed, Mar 7, 2018 4:21 AM
