New to Forum, Cat 22 orchard
Showing 1 to 10 of 14 results
abarhydt
Send a private message to abarhydt
Hi all, My name is Andy and I am new to the forum. I recently purchased a 1936 Cat 22 orchard model. The serial # is 2F7404WS.
I was wandering what the "WS" stood for at the end of the serial. The tractor needs restoration as well as the orchard seat and controls put back on, the previous owner did a top-seat conversion. I am glad to have joined and am looking forward to researching the information available here.
Andy
Wed, Nov 9, 2011 7:56 AM
zootownjeepguy
Hi,
Usually W stands for Wide tread version. The S is stamped when "Special parts" are installed as assembled at the factory, could be transmission gears or ???
Rich Salvaggio
D2 5U9917
Wed, Nov 9, 2011 8:48 AM
abarhydt
Reply to zootownjeepguy:
Hi,
so the "S" could be for the Orchard fenders, extended controls and sling-shot seat. It also has what looks to be a fuel heater on the block, behind the carb.
thanks
Andy
Wed, Nov 9, 2011 9:07 AM
W. SMITH
Send a private message to W. SMITH
Reply to abarhydt:
thanks
Andy
Andy, There should be a serial # plate in at least 2 places on your 22, one on the engine and one somewhere on the rear of the tractor. Is there a P after the WS on either serial # plate? My 22 says WSP after the number.
Wed, Nov 9, 2011 9:32 AM
abarhydt
Reply to W. SMITH:
I have not yet found the rear serial plate. I still have to remove the top-seat. The serial number I found was on the engine block, and did not have a "p" at the end.
Andy
Wed, Nov 9, 2011 10:10 AM
8C 361
Thank you received: 12
I'd leave the top seat on.
Wed, Nov 9, 2011 9:37 PM
gwhdiesel75
Reply to 8C 361:
The "WS" may be an error by the fellow at the factory who stamped the s/n plate. The "W" alone should stand for wide gauge. The "SP" afterward would stand for "special parts" as mentioned above. It is possible the fellow somehow didn't get the "P" on the plate. Just a theory.
The top seat is safer to operate than the tail seat. If you want the looks of a tail seat, go ahead and make the change. The tail seat is probably less common. But if you want to operate it to any extent, I'd consider safety too.
GWH
Thu, Nov 10, 2011 2:07 AM
abarhydt
Reply to gwhdiesel75:
GWH
The previous owner converted to the top-seat for those reasons, but I am going to restore the tractor and mainly use it for show, not real work.
Thu, Nov 10, 2011 8:59 AM
zootownjeepguy
Reply to abarhydt:
I have a D2 parts tractor, sn 4U1200SP on the block and 4U1200SPG on the transmission. I'm guessing the "SPG" designates gearing.
Rich Salvaggio
D2 5U9917
Thu, Nov 10, 2011 10:06 AM
zootownjeepguy
GWH
[quote="gwhdiesel75"]
GWH[/quote]
That's a good point! The tailseat could launch you like a catapult if you're not careful on rough ground.
Rich Salvaggio
D2 5U9917
Thu, Nov 10, 2011 10:10 AM
gwhdiesel75
GWH[/quote]
Also in backing up the machine if not careful you can crush yourself against objects near-by. I didn't appreciate that potential until operating one of Larry Maasdam's tail seat machines and Rough and Tumble a few years ago. You can do that little trick parking the machine in a row of machines on display. GWH
Thu, Nov 10, 2011 9:23 PM
