New purchase info d5 98j
Showing 1 to 10 of 14 results
D6c76a
Send a private message to D6c76a
Hey guys the d6c76a is doing great thanks to the help on this board. I found a tractor to put the fleeco rake on i got with the d6.
It's a d5 98j 525 couple questions, i see a lot of 94j and 96j,what are the difference between them? This machine looks to have auxiliary hydraulic hook ups. Also wide pads
What does she weigh,and how much hp,its a na 3306.anything in particular to look out for?
Thanks in advance
Thu, Nov 14, 2019 2:37 AM
Hello. What part of La are you from?, my daughter is down there visiting. Gary
Thu, Nov 14, 2019 2:59 AM
That early a 98J would have the D333C engine. 3306 didn't come in until 98J1134-up
96J is a powershift
94J is regular direct drive
98J is Special Application direct drive.
Thu, Nov 14, 2019 3:22 AM
96J is a powershift
The D6C is rated at 125 hp @1900 rpm. Operating weight with hyd control and 6S blade is 28,600 lbs.
Thu, Nov 14, 2019 9:18 AM
oops! you said D5, that would be 93 fwhp @1750 rpm, operating weight for 74" gauge is 19,100 lbs, 18,700 lbs for the 60" gauge, 74" gauge direct drive is 18,500 lbs, 18,100 lbs for the 60" gauge direct drive.
Thu, Nov 14, 2019 9:23 AM
D6c76a
Thanks for the info,I'm located in amite, la.
Thu, Nov 14, 2019 11:19 AM
Reply to D6c76a:
Yer welcome. ok
Thu, Nov 14, 2019 10:29 PM
D6c76a
Yer welcome. ok
Ok ,so the cat has been purchased!!! I'll try to upload some pics and a vid of the old girl. The old farmer said she has 30"pads on her. And a confirmation of auxiliary hydraulics.
Being a d333c engine,would it be the same ci as a 3306,or the smaller d333a?
Fri, Nov 15, 2019 9:12 AM
D6c76a
Reply to D6c76a:
Rome k/g our d6c with sweeps and screens,fuel tank guard,and straight bull blade came across the scales right at 36,000 lbs for reference.
Wondering if the d5 might be closer to 25,000 lbs? It has sweeps and screens, but a small blade.
Also seen a rating of as high as 120hp for a 98j,being a special ap. Any truth to this?
Fri, Nov 15, 2019 9:19 AM
Reply to D6c76a:
[quote="D6c76a"]Ok ,so the cat has been purchased!!! I'll try to upload some pics and a vid of the old girl. The old farmer said she has 30"pads on her. And a confirmation of auxiliary hydraulics.
Being a d333c engine,would it be the same ci as a 3306,or the smaller d333a?[/quote]
It would be the same 4.75"x 6" 638 ci as the 3306
As far as weight any added attachments will increase the weight, wider tracks, cabs/sweeps, roller guards.
Yes the rpm and fuel setting can be increased for ag tractors, but may increase operating temps. Later tractors had aftercoolers to help with this.
Fri, Nov 15, 2019 9:21 AM
D6c76a
Awesome info Rome,she will have a fleeco rake on her so not too bad a retirement gig ya?
Also I never run my stuff wide open,being a mechanic by trade, it just doesn't sit well with me.
Figure she will make a good pair for the d6c.
Fri, Nov 15, 2019 9:34 AM
