New problem for my 951c
Cat951
Send a private message to Cat951
Hello to all,
I tried a used fuel transfer pump that had given me, but the situation had not improved.
I then refurbished the original fuel transfer pump of the loader. I put new seals, leveled surfaces and replaced the gasket on the relief valve.
[attachment=14837]IMAG0072_1024x680.jpg[/attachment]Now I have good fuel pressure even at low speeds.
However, the first start-up of the loader is very difficult, it seems that every time should be prime the injection system.
I have a fuel leak from the first injector, it may be that this face losing pressure to the system after turning off the engine?
Also, with the engine off, if I unscrewed the relative injector line, fuel comes out. It 's normal?
[attachment=14836]Fuel Leak.jpg[/attachment]Even after 5 minutes after turning off, the engine hard to restart.
After the start, the loader with the new fuel transfer pump, has a lot of power and works well.
Mon, Sep 24, 2012 4:14 PM
Cat951
94 visits and no reply ... come on guys, tell your opinion!
if you do not understand some of what I wrote, I will try to explain. I do not know much English!
thanks
See you soon
Tue, Sep 25, 2012 10:48 PM
Dan Pratt
Reply to Cat951:
thanks
See you soon
Just a guess, but if fuel is leaking out, air is probably getting in when off. Air getting back to the injection pump distribution manifold would really mess up the overall prime.
Other ideas???
I would fix the leak for sure then go from there.
Dan
Wed, Sep 26, 2012 2:34 AM
catsilver
Reply to Dan Pratt:
Other ideas???
Dan
If the fuel is leaking up past the thread of the retaining nut, it is probably leaking between the nozzle holder and the nozzle lower down, probably because the nut has been overtightened at some time and squashed the nozzle down, this will also allow compression past the nozzle seat in the pre-combustion chamber and blow combustion gas past the nut and back down the fuel line, causing the fuel to aerate, the sleeve metering fuel system will put up with some of this until ithe engine is stopped, then the air separates from the fuel within the injection pump, causing air in all the fuel lines, then the engine will not start.
In other words, fix the fuel leak first, take the injector out, make sure it has a good seat in the chamber, make sure it is not squashed down, check there is a good clean seat between the injector and it's holder, put the retainer nut on with no seals first, to make sure it is clamping the injector and not going tight on the chamber top. If all this is OK, there should be no leak, but I reckon you will find the fault in these checks.
Wed, Sep 26, 2012 4:53 AM
Cat951
Reply to catsilver:
Hi catsilver,
thanks for your answer, as I understand it, the fuel flows as shown in Figure No. 1.
[attachment=14882]Figure 1.jpg[/attachment]
My problem is that I can not unscrew the holder with key 1-inch. I'm afraid that doing a lot of strength I can break in the prechamber.
Do you have any solution?
E 'possible that the leak occurs as in fugura No. 2?
[attachment=14883]Figure 2.jpg[/attachment]
thanks
Annulla modifiche
Fri, Sep 28, 2012 6:07 PM
catsilver
Reply to Cat951:
Hi catsilver,
thanks
Annulla modifiche
Hi cat 951, It is possible that the fuel is leaking as in figure no2, a check of the condition of the injetcor pipe end should confirm this, but if someone has screwed the top nut down so tight that you cannot get it off, they have doen this trying to 'cure' the leak. If you can't fix it by cleaning up the injector pipe end, you may have to get that top nut off, but drain the coolant out first, because the whole precombustion chamber may come out.
Fri, Sep 28, 2012 7:36 PM
Thank you received: 46
Reply to catsilver:
In a older tractor had fuel leak as in your last picture.Used emery cloth and dressed the ferals which fixed most of them.I think the nut bottomed out on the ones that still leaked so rapped teflon tape on top of the of the feral which fixed the rest.I don't us this tractor that much and it has lasted, but in your case of a working machine new fuel lines are probable the way to go.
Ray
Fri, Sep 28, 2012 10:19 PM
rjh-md
Reply to Ray54:
Ray
You will need an 1" socket and long bar to remove the injector retaining nut ,as at assembly the torque for that retaining nut is 100lbs ,precombustion chamber torgue is 150 lbs
clean taper in precombustion chamber ,and male taper on injector ,screw injector hand tight to splinded injection tube ,install injector and tube in precombustion chamber apply antisiezer compound to retaing threads ,and torque nut to 100lbs
If leak is solved ,and hard starting continues check rack limiter on governor for hanging up
Sat, Sep 29, 2012 2:42 AM
Cat951
Reply to rjh-md:
Hello guys,
sorry for my silence, I have not had much time to work on the 951 loader.
I removed all the injectors, clean the seats on the precombustion camber, clean the injectors capsules, one was a little slow, in fact was anointed fuel.
Refitted all with new gaskets and antiseizer-compound and reworked by hand connections of fuel lines.
No more losses, the loader starts well, I tried to 0 ° C and 1 min preheating. Even after two days the cranking was much better than before.
Thanks for the help guys!
Tue, Jan 29, 2013 1:03 AM
