New Member With Questions...
Showing 1 to 9 of 9 results
1939Cat
Send a private message to 1939Cat
Hello,
Glad I found this website and have a few questions. First one is my grandpa gave me this old dozer and he told me that it's a 1939 model. I believe it is a D8 but not for sure. Is the serial number that which is stamped on the block? Next question, I have tried starting this jewel and it's been probably 20 years since it ran. Pony motor will start but doesn't run long. Are there parts for this thing or can I buy a used electric start pony motor? From what I have read, it's best to keep the pony motor if possible. I am trying to get away from this hand crank pony since it kicked back and broke my wrist. Thanks for any help and it's well appreciated.
Fri, Nov 19, 2010 11:10 PM
8C 361
Thank you received: 12
If it is a '39 D8 the serial number will be on a tag near the left front of the engine below the water pump. It should start with 1H. It sounds like your pony has a restricted fuel supply. If it kicks the timing must not be quite right. Mine never kicks and starts very easily.
Welcome to the board.
Tom
Sat, Nov 20, 2010 12:34 AM
rustrunner
Send a private message to rustrunner
Reply to 8C 361:
Tom
1939CAT
Sorry to hear about your wrist. I would first take the carb off the pony completely disassemble and clean - these old carbs should not need any new parts, other than a gasket, but make sure that all the passages are clean and free of dirt/rust/other crap.
While you are doing this, try and find the service manual and parts manual for this tractor. I think Jensales has reproduction manuals for this unit.
I believe that the pony timing is set advanced. Don't remember which way it has to be turned to retard, but your books will tell. Second cranking a pony. If you broke your wrist, you may be cranking the pony incorrectly. That mag fires twice in a row and then skips twice. You need to get the pony on a compression stroke, where the mag is going to fire, position the crank so it is pointing up, grab the crank with just your curved four fingers(do not put thumb around crank), pull the pony through one mag firing. If it does not start, reposition for another pull. THis way, if it does backfire, the crank will pop out of your fingers, and with the motion of the pull, your hand will be out of the way when the crank comes around.
always.
Best of luck
Dan
Mon, Nov 22, 2010 7:50 PM
gwhdiesel75
Reply to rustrunner:
1939CAT
always.
Best of luck
Dan
1939 Cat, if you or a friend has a digital camera, please take a picture and post so we can see what you have. Also, let us know the serial number. GWH
Mon, Nov 22, 2010 10:06 PM
1939Cat
Reply to gwhdiesel75:
Thanks for the info. I did take the carb off and tank to clean but my grandpa was always good about running it empty. I'm taking it back off because it drained the gas tank in about an hour so something is wrong there. On the cranking, I did that but when it tried to fire, the crank rod got hung up on pony and didn't disengage. Of course my hand wasn't out of the way because I wasn't expecting it to fire after all these years and it caught my wrist. I am having an idea of taking that cog off the pony motor and putting a small pulley on it, taking a 12v starter putting a pulley on it, connecting them with a belt and seeing if I can start it that way. I'll take a picture of it. It's not pretty but it's there. I have about 3 more rolls of cable along with the dump scoop for it.
Thanks for all the help.
Happy Thanksgiving
Tue, Nov 23, 2010 1:51 AM
cojhl2
Reply to 1939Cat:
Happy Thanksgiving
[quote="1939Cat"]Thanks for the info. I am having an idea of taking that cog off the pony motor and putting a small pulley on it, taking a 12v starter putting a pulley on it, connecting them with a belt and seeing if I can start it that way. I'll take a picture of it. It's not pretty but it's there. I have about 3 more rolls of cable along with the dump scoop for it.
Happy Thanksgiving[/quote]
As rustrunner said, if you crank it correctly there will be no problem with it kicking. i think the electric starter will be a detraction and for no good reason.
Just make sure the timing is correct then follow rustrunner's advice. might add "make it a quick snap over center".
I've cranked a 3cyl hundreds of times and not once have had a problem. Although your's is not the same Cat the starting engine works the same way.
Wed, Nov 24, 2010 5:58 AM
1939Cat
Reply to cojhl2:
I went up to the dozer today and it is a D7 with the serial number 9G5785W. What year is this?
Wed, Nov 24, 2010 11:26 PM
chriscokid
Reply to 1939Cat:
here you go
http://www.chriscomachinery.com/ModelRD7.htm
Thu, Nov 25, 2010 4:33 AM
Thank you received: 64
Reply to chriscokid:
1938
here you go
My old Cat performance handbook shows 9G5465-7074 as 1939 models.
I don't see any models listed for 1939 on that picture roster???????
Thu, Nov 25, 2010 5:40 AM
chriscokid
oops... it is suposed to be 1939 the 38' year is listed just above it. thanks for catching that mistake.
Thu, Nov 25, 2010 6:22 AM
