new guy with a d4
new guy with a d4
Showing 1 to 10 of 20 results
nbent
Send a private message to nbent
i just got a cat d4 7u pretty cheap it needs work as usual on the fuel filters does any one know where to get one of the rods that go through the springs i have a broken one or do they come with new elements
d4 7u 6191
Tue, Sep 9, 2014 2:03 PM
sr4440
Send a private message to sr4440
You can get them from Cat.
They don't come with the filters
Tue, Sep 9, 2014 5:31 PM
Buddy
Send a private message to Buddy
Reply to sr4440:
I made two when mine broke.
I can not remember the size now but , it was ether 1/4 or 5/16 key stock cut to length .
I thin welded a flat fender washer to one end, drilled a small hole on the other end for the pen. WALLA !
Don't have to worry about breaking that one again. LOL .
Tue, Sep 9, 2014 6:05 PM
nbent
Reply to Buddy:
thanks buddy i hadn't thought of that
d4 7u 6191
Wed, Sep 10, 2014 6:18 AM
nbent
Reply to nbent:
has any one added hydraulics to one of these a neighbor has one with the pump driven out the rear of the machine is there an easier way to do this any help would greatly be appreciated
d4 7u 6191
Wed, Sep 10, 2014 11:49 AM
Thank you received: 51
Reply to nbent:
The rear pump is easy if you can find the right mounting hardware,but most of those pumps are getting very worn anymore.Cat made front mounted pumps with mounting hardware, it shouldn't be to hard to mount you can find the right stuff including the pluming. If you wish to put something together yourself I think Cat still sells the flange that bolts to the crankshaft to put a universal joint together to make a short drive shaft to power your pump.The pluming is the biggest job in you need to keep it out of your way to get to service points as well as putting it where you don't ripe it off by things hitting it.
Don't know your knowledge of hydraulics ,all the old systems where high volume low pressure.So if you are planning on using a blade you need to take into account what rams your are going to us to size the pump correctly as if the blade moves to slowly it is much harder to do a good job.But if you wish to us semi modern farm equipment pressure maybe more important than speed.
Wed, Sep 10, 2014 9:33 PM
7upuller
Reply to Ray54:
Hey Nbent,
I was talking to WyoCat (Chad) this morning. He has the Cat set up hydraulics and 4s dozer for your tractor with rear ports too. Send him a private message. Glen
Wed, Sep 10, 2014 10:45 PM
nbent
Reply to 7upuller:
Hey Nbent,
on the service meter on theses is it 4 digits that are all on hour intervals or is the far right digit in tenths
d4 7u 6191
Sun, Sep 21, 2014 12:44 PM
Sasquatch
Reply to nbent:
No tenths on these old hour meters, just hours.
Sun, Sep 21, 2014 9:00 PM
BillWalter
Reply to Sasquatch:
I have filter rods for sale; $5.00 @ plus postage; Bill Walter ; [email protected] or 816 891 8654
Sun, Sep 21, 2014 9:31 PM
nbent
Reply to BillWalter:
thanks bill i just made some with key stock and fender washers. thanks for the info on the hour meter as of now its showing 6137 hours on it
d4 7u 6191
Sun, Sep 21, 2014 11:53 PM
