New Forty Diesel
New Forty Diesel
yieldmap
Send a private message to yieldmap
Thought I'd share our latest find with you all. The Forty Diesel, 3G318 was found in the middle of Illinois nestled in a machine shed. In 1991, the owner had backed her in a shed, put on a fresh coat of paint, then died within a year. So there the old girl sat until yesterday.
The tractor appears to be pretty complete and in good shape. Undercarriage is good, both engines are free, feel like good compression, and the tin is pretty good.
The main clutch is working, but a rough pull and does not go over center. Right steering clutch appears to be stuck, left feels like it's working. The pony mag has some sort of issue, since they had an external coil wired up. The throttle control lever is stuck somewhere along the line or we would have tried to pull-start.
http://picasaweb.google.com/yieldmap/20090409FortyDiesel
Any ideas on how to free up the clutches?
The Laplant-Choate Blade brackets will be coming off. Anyone want a blade and brackets? The blade is not pretty and missing the center cutting edge, but mostly complete.
Thanks,
Sam
Fri, Apr 10, 2009 11:26 AM
JasonPayneCrawlers
Nice find I like those Forty Diesel, My brother want's to find one with a cab on it 😊 Looks like someone can't wait to drive it by his smile,enjoy your new toy
Fri, Apr 10, 2009 11:58 AM
gwhdiesel75
Reply to JasonPayneCrawlers:
Again, nice find Sam! GWH
Fri, Apr 10, 2009 7:28 PM
Steve A
Reply to gwhdiesel75:
Nice find Sam
On the main clutch there is a adjustment collar you will need to loosen up, likely the clutch has swollen over time and is now thicker than it was when parked. The cover is under the gas tank on my gas 40, after you get the main free and engine runing you will likely be able to free up the stearing clutches using the brakes or chain it to a big stump.
Good Luck
Fri, Apr 10, 2009 7:45 PM
d75
Send a private message to d75
Reply to Steve A:
Nice find Sam
Good Luck
Most common on those tractors the bell crank that pulls the clutch realease yokes where the steering clutch adj. is made gets rusted and froze up on the shaft. If you pull the cover that is right in front of the seat behind the levers is where they are located. Being that the lever is partialy back on its own my guess is that is where it is stuck. Also while you have the floor plates off it would be good to lube the brake shafts where the pedals attach. I also found it easier to adjust the main clutch through the bottom inspection cover just pull it up on some big timbers first. hope this helps.
Sat, Apr 11, 2009 2:22 AM
Catmatt
Send a private message to Catmatt
Reply to d75:
Nice find! Best of luck getting it running and moving again!
Sat, Apr 11, 2009 4:18 AM
| Kingaroy, Queensland
