New d25u!
New d25u!
budasterisk
Send a private message to budasterisk
Gang,
bought a 52 d2 5u yesterday in my area and will take a couple weeks to get back home. Guy has done lots of work to it over the years: clutch, steering clutches, some minor things and was used at his hunt camp to maintain the road in.
says the pinion would not engage and am taking one of of my parts d4 this aft and will swap it in. Saw the good videos from sasquatch on rebuilding them.
based on my very little understanding of how they work i would have thought that the pinion would at least stay engaged if you held the handle in the proper position. Actually now that i type this, the engagement leaver does not seem to be pushing the pinion forward but was only a cursory look at it until i go back or get it home. Undercarriage was in good condition.[img]http://blackdogbrewing.org/20210408_175706.jpg[/img]
Sat, Apr 10, 2021 12:24 AM
8C 361
Thank you received: 12
Would it not be best to pull start it to load it and get it home? Parts from D4 will likely fit but it is a fairly complex operation to do in the field.
Sat, Apr 10, 2021 8:12 PM
Reply to 8C 361:
the engagement gear,latches and sleeve may have become loose due to the bolts working out
Sat, Apr 10, 2021 9:17 PM
Thank you received: 62
Reply to dpendzic:
Here's a thread with the sequence to pull the pinion arrangement. It took me about 2 hours, not including the time spent fishing around in the clutch compartment for the pinion sleeve. https://www.acmoc.org/bb/discussion-d72/27795-d2-pony-pinion-gear-worn#226634
That was with everything having been apart before recently and anti-seized so everything came apart very easily
__PRESENT
Sun, Apr 11, 2021 4:08 AM
