New d2 owner in need on oil pressure routing info
m249bb
Send a private message to m249bb
Hello,
I have a 1950 D2 5u-6255 that is missing the oil pressure guage piping. The gauge is in place but the piping to the motor is not present. Does any one know where the oil pressure gauge tubing connects to a d2 engine😞 at? I have found a number of possible ports on the block but any not sure which spot is correct. Any info is greatly appreciated.
charlie
Mon, Sep 16, 2013 11:58 PM
Thank you received: 39
The usual connection is at the end (rear) of the external lube oil distribution manifold.
Tue, Sep 17, 2013 1:21 AM
Thank you received: 58
Charlie, my 5U has the pipe coming out of the hole at the right rear side of the engine block, adjacent to the block water drain cock.
Neil.
Tue, Sep 17, 2013 2:18 AM
m249bb
Neil.
I found it. You guys are the best! Thanks for the help everybody.
charlie
Tue, Sep 17, 2013 3:45 AM
