'New' D2 - Fuel pump/line/dryer/separator install
RHX
Send a private message to RHX
This is the first post with the new forum software!
https://youtube.com/shorts/aYbd6PPsUIc
Now, after shooting that video, the WIX 33046 inlet filter on the pump has been removed and replaced with a brass 1/8"NPT Male to 5/16" barb. The small inlet filter clogged too easy. Ahead of that, is going the https://www.amazon.com/dp/B075TZQ8LD
"CARMOCAR Fuel Filter Water Separator replacement for Marine Outboard Motor Mercury with 3/8" Barb x 1/4" NPT brass Fittings Replaces# S3213, S3214, 35-60494-1, S3213, 18-7932-1, 18-17928, 35-809097"
Ahead of the fuel/water separator, is going a 5/16" inline clear fuel filter. There is some stuff in the tank, catching it with an inline filter, before it gets to the S3213 fuel/water separator.
Where should the separator go?
https://youtube.com/shorts/x_18jYCXPow
Forum software is broken. No captcha challenge but it keeps asking me to 'complete captcha challenge'. Can't use forum :(
Sat, Mar 29, 2025 5:54 PM
Thank you received: 22
I put mine down beside the engine, just before the fuel line gets to the transfer pump.
Sat, Mar 29, 2025 9:49 PM
RHX
Thanks neil.
Here's the update:
https://youtube.com/shorts/y_aEk_C5I-4
Fuel line install fuel/water separator part 2 of 2
Wed, Apr 2, 2025 1:22 PM
