New boat anchor in the yard
Showing 1 to 10 of 15 results
PWygant
Send a private message to PWygant
Just got bad news on the diesel engine in the 4u....it's toast. Cost estimate for rebuild is beyond my means, so what now? Do I part out the hulk and have it sit in the back yard irritating my wife to no ends until the scrap vultures get it, try to sell it whole first, or look for a good replacement engine at a price I can afford? I've got about a grand I can use for another engine, or would I be better off to cut my losses and not chance another fiasco?
I'm going to get the original engine back and maybe put the thing together so someone could run it some and load it ( the engine still runs) . It's a shame, everything on the dozer worked and operated well, just puked oil.
Opinions?
Tue, Sep 30, 2014 9:36 PM
Thank you received: 24
Have you checked out after market parts and Cat Classic Parts ?I have had luck with parts from Regal,but it has been a few years so may not have as much any more for this vintage.
Tue, Sep 30, 2014 10:00 PM
7upuller
Reply to Ray54:
Hey Pw,
Did the tractor run ok? Explain why you had it looked at. Was the puked oil coming out of the stack? Glen
Tue, Sep 30, 2014 11:00 PM
old-iron-habit
Reply to Ray54:
Sems odd to be completely toast if it still runs. What are they saying is all wrong. Lots of difference between a fix for occasional use machine and a 10,000 hour rebuild.
Tue, Sep 30, 2014 11:30 PM
Reply to old-iron-habit:
How you recently bought it, "ran great but puked 4 gallons of oil"???
Anyways like OIH said, what EXACTLY is wrong that a repair can not be done verses needing a 10k hr rebuild?
I've seen lots of old iron repaired cheaply when they never should have been run again and for occasional use, they last a lng time.
Please Elaborate on the Issues.
Tue, Sep 30, 2014 11:47 PM
83Jim
Send a private message to 83Jim
Reply to drujinin:
Like everyone else, I hate to see an old machine left for dead, especially if the engine will run.
"puking oil" out the exhaust could be anything from bad injectors (relatively cheap to replace these spray-nozzle type) to bad rings (slightly more expensive depending on who does the rebuild) and of course bad pistons.
Sometimes these engines just need to be run for a while and get up to operating temp to determine their condition.
Of course you may be limited by your mechanical aptitude (like a lot of us are) and have to rely (and pay ????) someone else to do it. If you are lucky there may be another board member who is close enough to come out and look at this with you.
Just my .02 and good luck.
You only need two tools in life - WD-40 and Duct tape. If it doesn't move and should, use the WD-40 If it shouldn't move and does, use the duct tape.
Cat D4D 83J w 3304 PC engine, FOPS, s/t blade, D4F winch, air ride seat, "wobble" stick blade lever and D8H control panel
Cat 920 62K w 3304 PC engine, FOPS, 4 in 1 bucket
1995 Dodge Ram 2500 4x4 RCSB Cummins 5 speed
Wed, Oct 1, 2014 12:17 AM
Dozerman51
Reply to 83Jim:
Maybe you just have a "Wet Stacking" problem. Lots of things to check before turning it into a "Boat Anchor". Don't give up so quick. Lots of folks on this site have great insight and experience.
Joe Giraud
40' Cat D2/3J#4103
41' Dodge WC-12 1/2 ton Military 4X4 Pick-up
Wed, Oct 1, 2014 1:50 AM
Reply to Dozerman51:
Joe Giraud
40' Cat D2/3J#4103
You guys never went back to read his Thread!
Has nothing to do with "Wet Stacking"!
I quick searched his original thread and quick replied when I put his quote of 4 gallons of oil in my reply.
He has oil coming out of his engine in the flywheel area, else I read it too fast?????
Wed, Oct 1, 2014 3:49 AM
Dozerman51
Reply to drujinin:
Oh Boy!!!!! My Bad.
Wed, Oct 1, 2014 5:36 AM
mrsmackpaul
Reply to drujinin:
[quote="drujinin"]You guys never went back to read his Thread!
He has oil coming out of his engine in the flywheel area, else I read it too fast?????[/quote]
I guess this is what happens when people start a new thread that relates to something else and could have, perhaps should have continued on another thread as I read this this morning I thought there must be something I have missed but I thought I'll just shut my gob and see what happens
Paul
Wed, Oct 1, 2014 5:56 AM
Reply to mrsmackpaul:
Paul
To his "Newbie" thread where he states it comes out a hole in the bellhousing.
http://www.acmoc.org/bb/showthread.php?21263-Newbie
Wed, Oct 1, 2014 7:04 AM
Price Tractor Pull
Price Tractor Pull
