Need to ID Cat Thirty gov spring hardware
Showing 1 to 10 of 15 results
STEPHEN
Please, I need to figure out what the spring hardware is.
Book shows 2464A clip, two S1082 cap screws, and a lead car seal.
These parts connect the throttle cable to the gov spri g to the gov rod.
Also, what screw length is an S-292 ? Have tried 0s-0292 on the net but haven't found any info
I have the parts book, but the illustrations are micro sized & clear as mud
Thanks for any help.
Sat, Oct 26, 2019 10:13 PM
josh
Thank you received: 14
S292, 3/8 NC x 1 Drilled HD.
S1082, 1/4 NC x 1/2 Drilled HD.
Nothing yet on 2464A
Sat, Oct 26, 2019 10:57 PM
STEPHEN
Reply to josh:
[quote="josh"]S292, 3/8 NC x 1 Drilled HD.
Nothing yet on 2464A[/quote]
Thanks for that info Josh.
Maybe there is a pic out there showing the spring assembly without the housing ?
Sat, Oct 26, 2019 11:43 PM
STEPHEN
Reply to STEPHEN:
[attachment=55772]20191026_104637.jpg[/attachment] here is the parts book pic
Sat, Oct 26, 2019 11:45 PM
Bruce P
Thank you received: 40
Reply to STEPHEN:
Looks pretty much like a Sixty.
That clip is a piece of tin with a hole for the spring on one end, then, a hole in the middle for a screw to hold the throttle wire. It also has a couple ears that fold over to keep the wire end tidy. Wish I had a picture to show you.
Hope this helps.
BP.
Sun, Oct 27, 2019 3:33 AM
Steve A
Reply to Bruce P:
Hope this helps.
BP.
I am also interested in this thread as I need to make the same connection on my sixty project.
Sun, Oct 27, 2019 8:10 PM
STEPHEN
Reply to Steve A:
Very surprised that the books don't cover this in more detail, both visual and written. I have been looking over the parts, operator, and service books last night and noticed a few things.
The associated bolts have the heads drilled for lock wire (thanks for the hint Josh) so lead seals can be crimped (like a gas/electric meter)to show if the adjustment has been tampered with. The parts book reads three car seals, so the :
The lock bolt for S1078 screw (high gov speed)
Two S1082 cap screws for S1079 cover
Two cap crews S292 to secure S1077 housing to the engine
I am missing the clevis that secures the forward end of the gov spring to the lever S1742 and the 2464A clip.
It would be easier to replicate the parts if someone had a pic and some measurements.
Interesting that Cat was so concerned with tamperproofing the RPM, guess they had a few problems with exceeding the redline?
Everyone, thanks for your help so far on this puzzle, hope we get more info.
Sun, Oct 27, 2019 8:36 PM
STEPHEN
Reply to STEPHEN:
I searched through some parts and found these screws in the spring housing. Book says need two, but didn't see where it shows the adjustment lock screw, so three should be correct I guess.
Sun, Oct 27, 2019 11:42 PM
STEPHEN
Reply to STEPHEN:
Also found this clip. The folded end is missing part of the fold and that might let it slip into the throttle cable tube, messing up the RPM setting. This is how it was assembled with a wire instead of a cable using a 10-32 screw,washer, and square nut. The clip is stamped from 16 gauge steel
Sun, Oct 27, 2019 11:59 PM
STEPHEN
Reply to STEPHEN:
Haven't found a S-1081 Clevis yet. Anyone?
Mon, Oct 28, 2019 12:11 AM
Thank you received: 95
Reply to STEPHEN:
my Best and Cat 30 Parts Books for Best S/No's S-1001 to S-3100 & Cat S/No's S-1001 to S-4682, show the scans below with separate pictures of the parts.
Hope this helps a bit.
Mon, Oct 28, 2019 6:48 AM
