Need part number for generator
Showing 1 to 10 of 13 results
chriscokid
Does anyone know what the part number would be for the generator for a 1944 2T D4. or would anyone know what the AC delco number would be, mine is in need or rebuilding and the tag is missing with the delco numbers.
Sat, May 15, 2010 7:41 AM
1948catD4
Send a private message to 1948catD4
my parts book says the generator
part number is 4f89 6volt 115 watt for use w/ battery
generator p/n 6b1809 90watt for use w/ battery
generator p/n 7b8343 75 watt for use w/out battery
Sat, May 15, 2010 9:07 AM
Jon
Send a private message to Jon
Reply to 1948catD4:
My delco book shows 3 6V generators, 1101664, cw 17 amp 1102425, cw 25 amp 1106256
regulator for 1102425....5869
regulator for 1106256....1118243
Sat, May 15, 2010 10:09 AM
Thank you received: 19
Reply to Jon:
You'll have to do better than that with a description.
My parts book shows 9 different generators, Delco-Remy & American Bosch for 2T application.
Sat, May 15, 2010 11:43 PM
chriscokid
well all i can tell you is that the gen is no good and it was a delco brand gen. all it has to do is keep the bat. charged up, it has no lights or aux. power req.
Sun, May 16, 2010 12:32 AM
Reply to chriscokid:
That doesn't mean anything other than brand.
Does the regulator mount to the generator or not?
How many pole shoe screws per pole?
Drive gear tooth count?
Single gear or double gear drive?
Pictures would also help.
Sun, May 16, 2010 4:46 AM
Cysco
Hi Erik...........your thread here made me think about the generator on my D2. Just for the heck of it yesterday I checked the output on the generator and darned if it didn't show a little over 6 volts. I thought it was junk because of the condition of the regulator. I think I will look into it a bit further now.
Have a good day.....Bill
Sun, May 16, 2010 8:16 PM
chriscokid
Reply to Cysco:
well i called cat today and they said that there is only one gen. with the reg. mounted seperatly for the 2T it is 4F89 which has been discontinued. He could not give me the delco numbers, so if some one could help me that would be great. he also could not tell me the amps or watts either or the regulator number for that unit.
Tue, May 18, 2010 7:04 AM
The 4F89 generator is a Delco-Remy and is replaced by a 9F4992 which is a Delco #1102429. It is a 6-volt 115 watt unit for use with battery. Can be used with three different regulators....4F71, 8B7757 or 7F2946.
Do you need Delco #'s for the regulators?
I'm still trying to pin down the Delco # for the original 4F89. Got plenty of numbers, just trying to get a match.
Ok, think I got it and fixed my mistakes.
The original 4F89 is the 18 amp, 115 watt Delco #1102425.
Tue, May 18, 2010 7:33 AM
chriscokid
thanks OM,
yes i would like the numbers for the reg. if it not too much trouble. I am so glad that you and others are a big part of this BB, maybe one day i will have a library of information like yours!
Tue, May 18, 2010 5:35 PM
Jason 10/D4
thanks OM,
Hi Erik my 2t has an american bosch corp generator on it. Not sure if that is origional or not? Now my 7u Ht4 has a delco remy on it. Jason
Wed, May 19, 2010 1:39 AM
Earlcoate Charity Open Day
