Need part number for D6 9U u joints
John from Fresno
Does anyone have the part numbers for the 2 u joints between the engine and transmission on a D6 9U17383 crawler?
Thanks,
John
Sat, May 6, 2023 5:35 AM
PhilC
3H0301 for the spider and bearing assembly. transmission end
3H7364 for the spider and bearing assembly clutch end
1H8499 for the complete unit.
Sat, May 6, 2023 7:29 AM
Reply to PhilC:
UJ905 in the aftermarket world, for spider and bearings.
Sat, May 6, 2023 7:59 AM
John from Fresno
OM, thanks for the numbers. I was able to find some one Ebay. Local CAT dealer said the serial number was for a blade and I needed to get the correct serial number for the tractor. hehehe
Wed, May 10, 2023 11:12 AM
John from Fresno
Local Caterpillar wanted $115 for the U-joint but had non in stock. NAPA had them listed for about $90, but again non in stock. So, I turned to Ebay.  Found an excellent seller, excessinc, that had several and free shipping.  So, I got 2 U-joints delivered for about $80.  It is a little frustrating to install if you have never done it before.  First align the notches on the clutch output and the transmission input.  Make sure that you take a light hammed and push the small metal strap holding the caps on against the u-joint on the end.  Failure to do this will make it very hard to slip in the u-joint. There is not a lot of room.  And put the bolts in the u-joint caps prior to installing it in the tractor or you will find out that it is faster to install the assembly the second time around.  Don't ask how I know that. 😊 I have attached some pictures for your enjoyment.
John
 [attachment=72241]IMG_8960.jpg[/attachment] [attachment=72240]IMG_8959.jpg[/attachment] [attachment=72239]Ujoint_Label.jpg[/attachment]
Sat, May 13, 2023 11:01 AM
