Need part #
Need part #
Showing 1 to 6 of 6 results
cab
Send a private message to cab
Need part # for 12 bolts & lockwashers holding trunnion ball plates to track roller frame on early D8H.
Must be in blade parts book, can't find in parts book. Thanks.
Mon, Apr 4, 2016 9:26 AM
Depends on what plate you have.
Plate 5J2602 uses 1J5257 bolts
Plate 1J9424 uses 3295-A bolts
All use 3B4516 lock washers
Plates are interchangeable
Mon, Apr 4, 2016 9:58 AM
cab
Here is a pic if that helps.
Mon, Apr 4, 2016 10:14 AM
Reply to cab:
They look the same in the parts books. Better look for a part #.
Plate 1J9424 uses a 1J9424 trunnion.
Plate 5J2602 uses a 5J4321 trunnion.
Mon, Apr 4, 2016 1:43 PM
cab
OM is the second bolt part # correct or typo? 3295-A
Mon, Apr 4, 2016 9:59 PM
Reply to cab:
3295-A-Bolt is exactly what it says.
Mon, Apr 4, 2016 10:56 PM
brian18a
Thank you received: 70
3295A is a 1" x 2-1/4" nc bolt originally used on a Cat 60, replacement is 8S9093. All the sixty parts with a sufix A were renumbered to conform with Cats original computer. Makes a pain looking for parts as most part searches will not deal with number.
Tue, Apr 5, 2016 12:31 AM
