Need info on d-2
Need info on d-2
Showing 1 to 6 of 6 results
ross wilson
Send a private message to ross wilson
Thinking about buying a d-2 with blade and factory winch 5U12436 any one know the year ?????
Mon, Jun 10, 2013 12:12 AM
Lance Jones
My book shows early 1953 . That is a neat unit , don't come any better than that .and a Winch to Boot !! Good luck with it . LJ
Mon, Jun 10, 2013 12:34 AM
Reply to Lance Jones:
Looks pretty nice--good grousers, electric start pony, winch,etc. I don't know if that serial # is late enough for the extended clutch housing where you can replace the clutch without pulling the engine. The larger size front idlers, i think 23 1/2" are great for keeping the nose from diving down when you lift the blade. They are usually solid idlers vs the spoked that you have.
Mon, Jun 10, 2013 7:40 AM
Reply to dpendzic:
In the 2nd photo, the track adjustment looks pretty far out?
Other than that, it doesn't seem too beat up for a tractor that obviously has been used to skid logs.
Mon, Jun 10, 2013 6:09 PM
Gregness
Reply to drujinin:
Nicely equipped! I may use that Roll cage as a model when I build mine.
Tue, Jun 11, 2013 1:18 AM
Reply to Gregness:
I doubt that cage could withstand a roll but should be good for branches and widow makers.
Tue, Jun 11, 2013 5:20 AM
Inter674
Reply to dpendzic:
I have a very similar 'cage' on my D2 and I think in the trade they are known as FOPS - foreign object protective structure designed soley for intercepting falling tree limbs and the like which might otherwise kill you😞
I guess iin a roll over they might also provide some limited protection - depending on how strong they are and how well mounted - which on a D2 and D4 is difficult to achieve unless you somehow tie them into the main transmission castings.
Nice machine by the way😊
Wed, Jun 12, 2013 10:51 AM
