Need help....what is this.....
Showing 1 to 10 of 16 results
Thorinedcor
Send a private message to Thorinedcor
Purchasing this little guy and need to know if anyone knows what model this is. I guessing its about a 1947 to 1953 D2 or D3 chassis. Thanks in advance
Retired mechanic just trying to pass the time and stay outta the wifes hair.
Sun, May 24, 2026 1:22 PM
Thorinedcor
Sun, May 24, 2026 1:25 PM
Thorinedcor
Thorinedcor
Sun, May 24, 2026 1:26 PM
Thorinedcor
Thorinedcor
Sun, May 24, 2026 1:27 PM
Thorinedcor
Sun, May 24, 2026 1:30 PM
Thorinedcor
Thanks for the help in this..... I will be trying to track down the tags and get the model and engine serial asap.
Sun, May 24, 2026 1:31 PM
Thank you received: 78
If you show the rear sprocket / axle, I use that to tell if it's D2 or D4 based, but in any case it looks like an old 933 or 955. I think it's newer than the HT4 because of the side hydraulic tank, but I'm guessing basically. The breather dipstick in front of the gear lever looks D4-ish to me
Sun, May 24, 2026 2:01 PM
Thorinedcor
It has 5 impact rollers and solid rear sprockets with 3 holes.
Sun, May 24, 2026 2:08 PM
Thorinedcor
It is a pony start so no electrical....engine plate says 'TRAXCAVATOR' (I can guess what that means) and serial is # 11a2608. Might be a bit heavy for my 14K trailer. 933E is what they are calling it, assembled on a D4 chassis (maybe) this early of S/N might be a D4 chassis. It still has the 311 engine so cant tell by that.
Sun, May 24, 2026 3:33 PM
