Need help with Stromburg M4 Carb
chriscokid
I hope someone can help with a Stromberg M4 Carb for my best engine.
I have it all cleaned up but I wanted to know what the factory settings should be for the fuel and air mix. adj. screws
here is a M
http://www.oldengine.org/members/diesel/OldCarbs/Carb28.htm
http://www.wcroberts.org/Paige_History/Images/1918_Truck_carburetor.html
not sure what the diff is between a M4
Thanks in advance
Tue, Oct 25, 2011 8:44 PM
chriscokid
Well I have tried running the machine.
I am having problems getting it to run smoothly.
Not sure which way to adj. the fuel and air mix, now My arm is about to give out from cranking every few min.
I have attached some pics of the carb.
Tue, Oct 25, 2011 10:16 PM
naylorbros
Reply to chriscokid:
Is that a 2-Ton fuel filter that I see on that Stromburg? Sorry I can not help with the adjustments.
Ken
Tue, Oct 25, 2011 11:23 PM
D2BIGED
Send a private message to D2BIGED
Reply to naylorbros:
Ken
Eric ::: Is the " M " carb. for a single cylinder engine ; The " M-2 " for two cylinders ; and the " M-4 " for four cylinders ??????
Tue, Oct 25, 2011 11:46 PM
D2BIGED
Reply to D2BIGED:
Erik :::: Hurry, and get that engine running....The electric starter is getting weak !!!!!!!
Wed, Oct 26, 2011 1:20 AM
chriscokid
Reply to D2BIGED:
I found the info I needed back in my archives but thanks anyway.
Wed, Oct 26, 2011 1:33 AM
| Hartley - South Australia
Newby Hall Tractor Fest
