Need help with rod bearings
mike in ca
Send a private message to mike in ca
The local cat dealer ordered a set of standard bearings for me but the bearings that came in say .040". The info on the box says Glacier B4175 A .040" there is a piece of tape below the label with the number 5F2907.
As far as I know the crank in my tractor is still standard, the parts book I have says the bearing # is 4B747. Does anyone have the part number for the standard bearings in my tractor? The serial number on my tractor is 4G 2183
Mike
RD4 4G2183
Mon, Dec 16, 2013 2:53 AM
Rod bearings 4B0747 (2 ea per rod) replaced by 8B4332 (replaces 2-4B0707) = 3B2470. All standard.
Mon, Dec 16, 2013 8:24 AM
mike in ca
Thank you OM, I will try to get to the cat dealer in a few days and order the correct bearings.
Mike
RD4 4G2183
Mon, Dec 16, 2013 9:18 AM
