Reply to Denis:
D6 9U starter pinion clutch shaft bent
I can't really help since I am knew to this, but I can say I have a very similar problem, and took the advice to remove the clutch, and I discovered a bent pinion shaft. When I was trying to engage it it would stall the pony engine real fast, as you described, and to make sure I turned the main engine with the fan belt and it turned fine, so I knew the problem was somewhere in between. Now I am trying to get more information on the engagement arm lever that is inside, and what may have cause the shaft to bend, was it simply wear and tear over the years? My manual show the diagram for the pinion clutch, but does not provide information on the end of the shaft, what part may be missing there, and what the inside engagement lever is supposed to look like, the end of it is a little mangled and I am wondering if something broke off it, and should it be replaced as well? Is it possible that a part that is in between to make contact between the shaft and lever would have fell down and needs to be retrieved?
Anyone that can help I would appreciate it greatly as winter is coming and the snow here is wet and heavy... eventually we need the cat to move the snow banks...
Denis
[quote="Denis"]D6 9U starter pinion clutch shaft bent
Denis[/quote]
I think I may have a bent pinion shaft also...
My issue is that even though the pinion gear is completly disengaged from the diesel motor flywheel, when I engage the pony motor clutch it instantly stalls the pony motor. The problem I had is that the four bolts holding the assembly on the end of the pinion shaft fell out and the assembly 'flew' off, bending the 'small spring loaded' rod. This assembly (actually a cylinder open on one end) has the 'spring loaded dogs' that release when the main motor spins this pinion shaft fast enough. After bending this rod back and re-installing the assembly and making sure the pinion gear is disengaged... Engaing the pony motor clutch totally stalls it, so something is jammed/bent inside. : ( My only hope is to try to reverse the pony motor (using the rope/pull start) while reversing turning the pinion shaft in the hopes that something will become unstuck.
Any ideas?
In order to take the pony motor pinion shf
