Need help with cat parts ID
Showing 1 to 6 of 6 results
mike in ca
Send a private message to mike in ca
Over the years my dad has picked up old cat parts here and there in his travels, I have no idea what they are or if anyone out there needs them.
Here are the part numbers
2B5458
1F2358
2B487
2B3130
L 780 - looks like a radiator cap
4B4553
we also have a valve cover for a two cylinder cat engine, it has two holes for the mounting studs but no part number stamped that I have seen.
I appreciate any help identifying these parts.
Mike
RD4 4G2183
Fri, Jun 21, 2013 12:12 PM
d9gdon
I tried to look them up in SIS, but there were no entries. I guess they were never computerized.
Fri, Jun 21, 2013 6:48 PM
mike in ca
Reply to d9gdon:
I will try to get a picture of the parts today. None of them look like they are from a D4.
Mike
RD4 4G2183
Fri, Jun 21, 2013 10:02 PM
josh
Thank you received: 14
Reply to d9gdon:
L780 is a radiator cap- general usage, post pictures, that may help
Fri, Jun 21, 2013 10:24 PM
Kelly
Reply to josh:
Mike in ca.
Number 1F2358, is the only one in an old price list book I have, Jan.7th, 1985 and was priced at $180.76.
Kelly
Sat, Jun 22, 2013 2:01 AM
mike in ca
Reply to Kelly:
Mike in ca.
Kelly
[attachment=18249]100_2891.jpg[/attachment]
Here are the mystery parts.
Mike
RD4 4G2183
Sat, Jun 22, 2013 10:49 AM
brian18a
Thank you received: 69
Reply to Kelly:
Mike in ca.
Kelly
Numerical parts record says:
2b5458 serviced as 2b5461 Bell assembly oil pump fits diesel 50 1E963 up, Diesel 35 6E1472 up and diesel 40 3G1 to 131
1F2358 cover pinion bearing final drive fits D8 1h, 8r, and 2u series
2b0487 elbow-air cleaner fits Diesel 50 1E463 up and RD7/D7 9G1 up
4b4553 serviced as 4B4552 bracket assembly compression release fits D8 1H2401 up, 8R all and 2U all
The radiator cap fits many things gas 10, 15, 20, 25, 28, 30 35, 40, 50, 70, R5 and diesel 35, 40, 50, 75, RD6, RD7 RD8
2B3130 pipe water outlet starting engine, used on Diesel 50 1E560 up and RD7 9G1 to 2646
Sat, Jun 22, 2013 10:52 AM
