Need help on pony motor rod bearing torque
daves2035
Send a private message to daves2035
Hi, I am assembling a pony motor on a D2. I started to install the rod caps, the torque spec is 58 ft pounds on 5/16 bolts. When torquing the bolts it seems not to bottom out. I have 30 ft pounds on so far. I am afraid that they may break. Has any one come across this.Looking for help.Are they available yet if they break? Thanks
Mon, Sep 26, 2011 3:34 AM
That's way to high for a 5/16 thread. Where did you obtain that spec?
Your 58 ft. lbs. is more in line with main engine rod torque. I don't recall seeing a pony rod bolt spec in the Cat literature.
http://engineershandbook.com/Tables/torque.htm
Mon, Sep 26, 2011 4:30 AM
Mike Meyer
I'm pretty certain those pilot motor conrod nuts only get tightened to 14 foot pounds, the heads are 25 pounds from memory.
regards
Mike
Mon, Sep 26, 2011 4:56 AM
daves2035
Reply to Mike Meyer:
regards
Mike
Thanks guys for the help
Mon, Sep 26, 2011 5:15 AM
64farmboy
Reply to daves2035:
Yep, main rods on a D2 are 58 ft lbs
Regards Dennie
Mon, Sep 26, 2011 5:24 AM
