Need Help Identifying Caterpillar THIRTY - 1925 ?
Showing 1 to 7 of 7 results
TexasTractors
Send a private message to TexasTractors
Hi here is a Caterpillar Thirty and we found some numbers on the flat area behind the Shifting area S1641 (2nd picture) and above the PTO / behind the seat area S1663 (3rd picture). S-463 is on one of the other pictures and at the bottom of the radiator side S2339. See all the other numbers we pictured too. Can someone tell me if any of these or which is the serial number # or if it is a 1925 based on the numbers above the PTO area or behind the shifting area? Thanks. This Cat 30 we assume may be stuck but we've only tried to turn it by hand. It's missing the magneto and gas tank as you can probably see. The oil looks brand new though and the running gears are 85-90% so that is good. Thank you for your help! -Robert
[attachment=24121]imagejpeg_13 Large.jpg[/attachment][attachment=24110]imagejpeg9512 Large.jpg[/attachment][attachment=24111]imagejpeg_9 Large.jpg[/attachment][attachment=24113]imagejpeg955 Large.jpg[/attachment][attachment=24112]imagejpeg9516 Large.jpg[/attachment][attachment=24118]imagejpeg9518 Large.jpg[/attachment][attachment=24117]imagejpeg9517 Large.jpg[/attachment][attachment=24116]imagejpeg953 large.jpg[/attachment][attachment=24120]imagejpeg9515 large.jpg[/attachment][attachment=24114]imagejpeg_3.jpg[/attachment][attachment=24119]imagejpeg9519 Large.jpg[/attachment][attachment=24115]imagejpeg_2 large.jpg[/attachment][attachment=24109]imagejpeg_6 Latge.jpg[/attachment]
Sun, Jul 6, 2014 8:30 AM
gary ca
I am no expert on number locations but I did find my engine serial number right behind the number 4 cylinder. There is a large flat spot there right where the engine bolts to the transmission case. Your fenders are missing so your tractor serial number is gone too. There must be another area for the tractor number and hopefully someone else will chime in.
Sun, Jul 6, 2014 9:10 AM
chuckb
Garlic Pete is correct about the casting numbers I believe that this 30 is 1928 or later going by the large track adjuster springs and manifold pics a 1925 would also have a tube style radiator once the fender tags go missing it is very difficult to date a 30
Sun, Jul 6, 2014 9:58 PM
dieselfreakcjw
Send a private message to dieselfreakcjw
Reply to chuckb:
^^ Agreed, has a wide seat which is a 1926+, big springs on the roller frame, and new style radiator, newer manifold. Looks like a nice find though! Mine's currently undergoing surgery as well.
Caterpillar 30 PS244
International Harvester T-40
John Deere 720 Diesel
Tue, Jul 8, 2014 1:41 AM
terrywelch_archive
Reply to dieselfreakcjw:
My two 30s are a bit different. The oldest is PS 75 the number is stamped in the casting right behind the seat .
Terry
Tue, Jul 8, 2014 4:46 AM
TexasTractors
Reply to terrywelch_archive:
Terry
Thank you for the good information. It sounds from the parts seen this is a 1926-1929 model. That flat area behind the seat and above the PTO has # S-1663 which would make it a 1925 model but that doesn't appear to be the serial # then if it has parts on it later than that.
This is in British Columbia and I deal in old tractors and such. It's about 350 miles northeast of Seattle by Armstrong, BC. With scrap prices and what my customer has into it he said he needs $4,000 firm. I think he's probably has a little wiggle room and $3,500 may or may not get it bought. Maybe that is too much for what's there not sure. The good thing is they have a heavy duty machine there that can load it on any flatbed, stepdeck, etc.. I do work with shipping items and can get this to the states for $1/mile or less depending on distance. Maybe even .75 mile or something like that but it depends on distance and where too like it'd be a lot easier to go to Omaha than California I imagine. Also as I said earlier It's missing the magneto and gas tank as you can probably see. The oil looks brand new though and the running gears and sprockets, etc. are 95% so that is good.
The same customer in BC has a working OC-4 Oliver with Blade for $3,000 there. There is diesel in the oil and hasn't been started in a year now but it does turn over. Also in the U.S. know of a Caterpillar 50 FIFTY Gas Crawler with A-Frame Blade in WY. I need to verify if it's stuck or not but customer told me it has a good undercarriage. I have a couple pictures and that's at $1,900. Robert at The Tractor Barn 512 573 8359
Tue, Jul 8, 2014 10:07 AM
janmeermans
[quote="Garlic Pete"]All of the pictures you posted are of part number or casting number. Caterpillar almost always casts the part number into their parts. Each part has a unique number. Most metal parts also have a casting number cast into them, which is different than the part number. Just a little after your tractor was made, Caterpillar standardized on a system of a number, a letter and four numbers for the part number. I believe the pictures you posted are of part numbers, rather than casting numbers, though.
As gary ca noted and pictured, tractor serial numbers are generally stamped into a tag, which is screwed onto the tractor. The serial number is also usually stamped into the steel underneath that tag, in case the tag gets damaged or lost. On the Thirtys, those tags were large brass tags, about four or five inches square, which were attached to the tail end of the fenders. Unfortunately, this was usually the first area to get torn up on a tractor and those fenders were usually either bobbed or removed entirely, as they have been on your tractor.
There are a number of places that serial numbers can be stamped on the tractor besides on the fenders. As gary noted, one of the most common areas is near the number 4 cylinder on a flat spot on the block. There are a number of other places, though, and there didn't seem to be a standard for which place they chose to stamp those numbers. I know another common place is on the right side of the transmission case, right up near where it bolts to the bell housing. This place is really hard to see and clean up because it is right behind the track and also behind the side panel which is supposed to be there. There are several other common places, though. Someone more familiar with the Thirty will probably chime in here and give you all the places to look.
Caterpillar Thirty serial numbers generally begin with an S or a PS. The S tractors were built in Stockton and the PS tractors were built in Peoria. Caterpillar Thirtys were built during the period right after the 1925 merger while Caterpillar initially operated in Stockton, California. Shortly after the merger, Caterpillar looked for a new factory location and settled on Peoria, Illinois. There was a short while that they operated both factories at the same time.
Pete.[/quote]
Pete,
Just today, a Quinn employee who also collects told me the S was for San Leandro and PS Peoria. I have no idea one way or the other. Just passing it on.
I looked at a THIRTY this week and then three more today. I can't read much of anything on the three today after checking behind the fourth jug on the flat spot. All three tractors are missing the fender plate. The one that is for sale that I looked at on Friday had this stamped on the flat spot (and no fender plate, of course)
30
4
18
29
The stampings as shown above would be if you were sitting in the seat and on the right edge of the engine block. These almost seem like they show the date of manufacture. I could not even faintly see an S or PS on any of the four tractors that I looked at. As someone already posted, the THIRTYs are hard to trace once that fender plate goes away.
Can anyone add to the discussion on the stampings above?
Jan
Sun, Jul 20, 2014 7:51 AM
4tcompost
Send a private message to 4tcompost
Reply to janmeermans:
Pete.[/quote]
Pete,
30
4
18
29
Jan
We have some thirtys also with what look to be dates stamped in the same place, maybe the dealer stamped them when they got them from the factory? Or they stamped them when sold for warranty issues, It's anybody's guess
Sun, Jul 20, 2014 8:47 AM
