Need help Identifying cat engine
Showing 1 to 10 of 12 results
XtremeXcavator
Send a private message to XtremeXcavator
I just came across a cat six cyl. dsl. eng. and I do not know what model it is. The tag say's 2s 16055. It has old canister filters. Thanks, Jim Gangle
Wed, Apr 28, 2010 7:06 AM
Hmmm, my info shows the 2S series to be a D8800 (4-cyl) engine produced from 1942 to 1946.
Could the 2 be a 3? A 3S would be a D17000.
Wed, Apr 28, 2010 7:23 AM
josh
Thank you received: 14
My book shows 2S 5501 up as "Miscellaneous engines" ?? That is from the sn section of a paper NPR. Perhaps some part or casting numbers off the head and other places might help.
Wed, Apr 28, 2010 7:52 AM
KCB
Send a private message to KCB
Jim, also double check the number part. The 2S, 3S, 4S ... series all end much lower than 16,000. The only industrial engine of this vintage that runs up into 16,000 + would be the D318 (5V).
Wed, Apr 28, 2010 7:58 AM
Rd6 plower
Send a private message to Rd6 plower
Reply to KCB:
A Picture would be even cooler!:cool2:
Wed, Apr 28, 2010 1:13 PM
bruce oz
Thank you received: 23
Reply to Rd6 plower:
hello ,the 2s number show in the cat serial number book as misc engines .
there are the numbers from manual numbers .
2s10000 D318 replacement engine
2s10100 D342 replacement engine
2s13000 D348 vehicular engine v12 engine
2s1000 D8800 replacement engine 4cly engine
bruce oz
Wed, Apr 28, 2010 1:53 PM
XtremeXcavator
Reply to bruce oz:
bruce oz
I will take a pitcure of it on my phone. My guss is it is a D333.It has the intake built in the head and the head patrudes wider than the block with small freeze pluges in it. To me it look's like the engine in the first D5's and D6 b's. Jim
Wed, Apr 28, 2010 4:41 PM
bruce oz
Reply to XtremeXcavator:
D333 engine -http://www.machinerytrader.com/listingsdetail/detail.aspx?OHID=6955642
bruce oz
Wed, Apr 28, 2010 5:03 PM
Rd6 plower
Well if that's the case you got your self a snappy motor!!!:whip:
Hey Bruce:hail:, the 342 isn't that the 14a-15a D8 motor? Now if that replaced the D318 what kind of work were they doing with it?
Wed, Apr 28, 2010 10:35 PM
XtremeXcavator
That does look like the motor Bruce, D4 Dan at Granger Tractor asked what the PT# on the block was, He said a D333 would have a 7M XXXX no. but mine is 5S 6777 and 1P 6369 on the head. Jim
Thu, Apr 29, 2010 8:12 AM
bruce oz
hello Rd6 plower ,i put a full stop after each engine ,lol,no they weren't update for the next engine ,
XtremeXcavator,i found 1P6368 1P6370 under D333c ,but didn't find 1P 6369 ..
om will have better book than the one i have ,bruce oz
Thu, Apr 29, 2010 9:37 AM
