Need Help
Need Help
Cattle237
Send a private message to Cattle237
Need a precumbustion chamber 4f8517 for D315 engine also retainer 4f5678. Have found a chamber with part # 2S1273 for D315 engine and was wondering if this part would work. This for a D4 7u serial # 15097
Any help would be greatly appreciated. Thanks
Fri, Apr 14, 2017 6:43 AM
josh
Thank you received: 13
The part numbers cross, it should be a direct replacement.
Fri, Apr 14, 2017 7:53 AM
Thank you received: 39
Reply to josh:
2S1273 is the correct (1-pc) replacement for the early D315/D318. (no retainer required)
Also requires a 5H7225 injector retaining nut which is shorter than original nut.
Seal ring is a 7B6868.
Fri, Apr 14, 2017 8:00 AM
Cattle237
[quote="Old Magnet"]2S1273 is the correct (1-pc) replacement for the early D315/D318. (no retainer required)
Seal ring is a 7B6868.[/quote]
Thanks for all the help.
Fri, Apr 14, 2017 9:41 PM
