Need help 2 identify old cat..
Old-skool
Send a private message to Old-skool
I came across this awhile back and dont know much about it, and really dont want to just scrap it like most say i should untill i find out more..its an older small cable style dozer, with the pony motor..here is the catch, the cylinder head is gone..it has been coverd up..couldnt find any tags but did on number on engine block.if u are sitting in seat it will b on your right side of block..it lookd like 438522..i will attach pics..is this a lost cause and aint worth fixing..bc i hate to see old equipment sitting in scrap yard...
Sun, Feb 3, 2019 2:28 PM
PhilC
4B8522 is the casting number. The serial number should be on the silver riveted plate above that number.
Regards
Phil
Sun, Feb 3, 2019 2:31 PM
gauntjoh
Librarian
Thank you received: 8
That looks like a J series D2 with a toolbar dozer. The toolbar dozers are much sought after for these machines.
The tractor serial number should be stamped on the rear of the transmission case top left hand side when looking at the rear of the tractor. It is as previously said also on the top left hand side of the engine block when sitting in the seat. If the two numbers are different then it means that the original engine has been changed at some point in it's life.
Sun, Feb 3, 2019 4:35 PM
STEPHEN
Reply to gauntjoh:
[quote="gauntjoh"]That looks like a J series D2 with a toolbar dozer. The toolbar dozers are much sought after for these machines.
The tractor serial number should be stamped on the rear of the transmission case top left hand side when looking at the rear of the tractor. It is as previously said also on the top left hand side of the engine block when sitting in the seat. If the two numbers are different then it means that the original engine has been changed at some point in it's life.[/quote]
Got to be a D2 J. I don't think it has a toolbar blade, the mouldboard doesn't look right, but could be a 2S blade with some added welding. The lift cylinders are not Cat. I would like to get the sheet metal, it looks alright so far. Wide gage?
Sun, Feb 3, 2019 8:27 PM
MTD2
Send a private message to MTD2
Reply to STEPHEN:
Looks like it could be a LaPlant Choate dozer. I have one from a narrow gauge d4. Looks real similar anyway. Pretty heavy for the d2. Certainly not for the scrap yard! Just needs a new home! Look for the tags that the guys mentioned before. There should be a tag or stamped number on the blade.
Sun, Feb 3, 2019 11:01 PM
Reply to MTD2:
Thats a 5J series D2
Sun, Feb 3, 2019 11:28 PM
nomorejohndeere
Send a private message to nomorejohndeere
nice canopy
Mon, Feb 4, 2019 12:05 AM
Old-skool
Reply to nomorejohndeere:
nice canopy
I will go out and do some more looking for more info on it...somebody had suggestd that i could use a head off an old cat motor grader..tryn to find a trailer to load it on and get it back to my buddies shop so we can see what we got and where to go from here..
Fri, Feb 8, 2019 11:05 AM
Reply to Old-skool:
Good! Need help, theres plenty here on this site.
Fri, Feb 8, 2019 10:38 PM
