need bearing source
need bearing source
Showing 1 to 10 of 17 results
Jack
Who still stocks main and rod bearings for a D2 5U engine, both -0.030. Cat has the rod bearings at $pretty steep, but I'd use them if i can't substantially beat their price and still get quality. I havn't found any mains.
I thought maybe I could run this shaft again standard but when I got in there was water damage on the journals.
Any suggestions will be much appreciated. (I still have a D7 3T/17A wet clutch I'd trade in a second.) Thanks,
Jack
Tue, Jan 30, 2007 9:25 AM
Thank you received: 37
Hi Jack,
I don't have a source for bearings but this info might help the search.
I wish folks would share more of their bearing sources as it seems to be a constant scramble........or maybe it's a secret.
On an outside chance try www.regalcorp.com
D2, 933, #212 grader Models 3J, 5J, 4U, 5U, 11A, 9T, 79C
Rod Brg. w/rod # 5B419 uses #2F1083
Rod Brg. w/rod # 6F4324 uses #4H3026
Main set w/crank # 7B9079 uses #5F1081
The rod bearings are also the same (match the rod numbers same as D2) for the D4
Models 7J5104-up, 2T, 5T
Tue, Jan 30, 2007 10:43 AM
Jack
Hi Jack,
Thanks, O.M. I'll give it a shot.
Jack
Tue, Jan 30, 2007 2:28 PM
brialin
Send a private message to brialin
Reply to Jack:
Jack
I have had luck in the past getting engine parts from a local machine shop that does engine rebuilding. They have catalogs full of parts for any engine you can think of. Of course maybe caterpillar has found a way to keep everything to themselves. Good luck.
Tue, Jan 30, 2007 8:11 PM
Jack
Reply to brialin:
Of course these bearings are nothing like a normal insert bearing and would have to come from altogether different manufacturing methods, but that's why they lasted 50 years. I think that's two reasons why the regular bearing houses don't have them. I have the local rebuilder working on it now and he's having no luck so far. Different rebuilders use different sources so maybe something will turn up. Your suggestion is a good one but I already have them on it. Thanks.
Jack
Tue, Jan 30, 2007 11:54 PM
Reply to Jack:
Jack
This was a one time ad, never heard from again.
Mite be worth a call.
ACMOC ad
“All Cat Bearings Avail”
“Can reline old shells”
1-800-233-6934
509-999-2199
The Ram Man
Jack Bunton, Pres.
Ram Engine-Vintage Machine Works-RPM Service Center
Wed, Jan 31, 2007 3:36 AM
Jack
ACMOC ad
1-800-233-6934
509-999-2199
The Ram Man
Jack Bunton, Pres.
Gave it a try. That area code is for Washington/mid Columbia area--right across the river from me. I never heard of the outfit. The guy on the other end never heard of it either. I suppose we can pitch that number into the circular file.
We're looking at another option--maybe a good used crank in the bearings that I have instead of a regrind. I'm betting someone rolled a new set of bearings into that engine before they trashed it. The wear in the shells isn't too bad.
Cat wants about $650 for the undersize rod inserts for four rods, close to $700 for standards. I'm avoiding it.
Didn't have a chance to try regalcorp today, may wait. We're prowling Jim's yard for another crank first.
Thanks for suggestions, will keep you posted...
Jack
Wed, Jan 31, 2007 10:53 AM
alan627b
Send a private message to alan627b
Reply to Jack:
Jack
Might be of help...
http://www.engnetglobal.com/images/enhanced/productdetail/PAR017_cat.aspx
Wed, Jan 31, 2007 12:16 PM
Bob C
Send a private message to Bob C
Jack,
Ram still has a web site WWW.ramengine.com and the 800 number is the same as posted above.
Bob
Wed, Jan 31, 2007 12:39 PM
KidNV
Send a private message to KidNV
Reply to Bob C:
Jack,
Bob
OM,
2F1083 $27.48 regal $166.65 cat
4H3026 $non-stock $139.99 cat
5F1081 $out-of-stock, but shows as only part of 5F1073,5F1074,5F1075,1076, cat prices for those, in order, $155.61,$115.56,$203.27,$244.13
Try MotorWarehouse in SAC.. remember the parts sources link in Archives at ACME
Wed, Jan 31, 2007 2:18 PM
Reply to KidNV:
OM,
Hi KidNV,
Thanks for posting your source list again.
What would really help is having folks actually state where they were successful
at getting the bearings they need. Very frustrating to have to shop the nation to put together mismatched brands/sets of bearings. If you can get them at all.
Wed, Jan 31, 2007 10:36 PM
MSTEC STEAMFEST
