Need advise on how to remove fuel injectors from 1946 D6-4r
pulpdeth
Send a private message to pulpdeth
Dear Fellow enthusiasts,
How do I properly loosen the very large nut which holds the fuel injector into the block.
Previous owner uses a hammer and chisel to loosen the nuts.
That's no way to treat a grand ole' lady.
Please tell me how to do it properly.
Thank you for your expertise.
Chris
Mon, Mar 5, 2012 5:56 AM
Jack
You borrow or buy a Cat injector socket. It has a relief in the side to straddle the fuel line and can turn the nut 1/12 turn at a time. They tend to be stuck pretty darned tight.
I borrowed one from the Cat dealer and broke it. Replacement cost me something over $70, but I kept the old one, welded it up and welded a nut onto the top of it so I could use a HAND impact wrench and socket on it. I now have a better setup than the new one.
Good luck and success. I hope you don't break an expensive wrench in the process.
Mon, Mar 5, 2012 6:44 AM
Reply to Jack:
Hi Chris,
Welcome to the BB.
Here is a link to where Carlscat made one for a D2.
Be aware there are two sizes of injector retaining nuts.
The D2 size and, a larger one for D4 etc. Be sure to measure your nut and purchase a socket to suit then modify as per the attached thread.
Hope this helps.
http://www.acmoc.org/bb/showthread.php?7160-Need-D2-3J-Injector-Removal-Tool&p=42898&highlight=#post42898
Mon, Mar 5, 2012 9:37 AM
