Need a little help on my 8T Grader
Roydsracing
Send a private message to Roydsracing
After listening to my brother control the pony speed with the choke I just fixed the pony governor and can't seem to find my operation and maint. manual. Just need to know the no load high idle for the pony. Got to set that before I can put the hood back on.
LeRoy
Mon, Aug 9, 2010 8:41 AM
Thank you received: 20
High rpm is 3350
Low is 800
Mon, Aug 9, 2010 9:11 AM
Roydsracing
High rpm is 3350
Low is 800
Thanks Old Magnet. I'm on my way out to set it and be ready to go in the morning. Just amazing how one little fix seems to lead to others.. Had to fix broken flanges and repair a rotted out exhaust system. Original problem was the adjuster for the governor spring was broke. Seemed easy enough until you start unbolting all the stuff in the way.
Thanks again
LeRoy
Mon, Aug 9, 2010 9:23 AM
