Need a D69U water pump
Showing 1 to 6 of 6 results
22rimfire
Send a private message to 22rimfire
I need to find a water pump for my 1956 D69U.
I tried changing the seals and bearings but it still has a leak from
the bottom of the pump.
Any help wll be appreciated.
1956 D6 9U
Fri, Jan 30, 2015 4:37 AM
22rimfire
Also does anyone have a diagram of the water pump
1956 D6 9U
Fri, Jan 30, 2015 9:15 AM
Thank you received: 43
Reply to 22rimfire:
I had a water pump that leaked after 2 rebuilds thought it was time to stop all wrenching,as I don't claim to be a mechanic.Turned out to be combustion gases escaping from engine around the precombustion chambers. A short term fix is taking the rubber seals out of the radiator cap. If the chambers look good as well as the seal washers then the fix gets to be real work.The seats for the precups need to be ground ,there was a thread that explains how to do this if you need to have this done.
Fri, Jan 30, 2015 9:48 PM
22rimfire
Reply to Ray54:
Mine is leaking just trying to fill the thing up with water.
Not even running. The new seal just does not want to seal off with the new impeller.
1956 D6 9U
Fri, Jan 30, 2015 11:10 PM
gemdozer
Reply to 22rimfire:
I check tomorrow but should have a spare water pump
Sat, Jan 31, 2015 4:42 AM
I have done some jiggering to make some water pumps seal. Seems likely that the impeller is not actually contacting the carbon ring of the seal assembly. Have seen them missing the ceramic seat glued to rear face of impeller or possibly there were some impellers that never had the ceramic seat and the carbon ran directly on the cast iron impeller hub. It is usually possible to extend the range of the seal bellows slightly by bending the retaining tabs on the brass seal cup up a little to get good contact between seal and seat.
Sat, Jan 31, 2015 10:32 AM
gemdozer
I check his morning and still have a d6 water pump
Sun, Feb 1, 2015 1:46 AM
