Mystery Metal D-2
Mystery Metal D-2
Showing 1 to 10 of 12 results
Thank you received: 233
I “borrowed” the cover from my freebie for you D2; I couldn’t help notice all of the stray chunks in the bowels of this poor old thing. I don’t seem to see where all of the broken bits came from. I will remove everything with a magnet and look harder with a bright light. It came to me for parts and will likely be a parts machine.
Tue, Dec 16, 2025 12:09 AM
Thank you received: 142
Gee- looks like someone might have heard some noise from the looks of the bottom of that case. Those "chunks" look pretty heavy, more like a gear went south! Bearing cage or casting broken? Pictures and let us know what you discover.
Tue, Dec 16, 2025 2:22 AM
side-seat
Thank you received: 15
PTO shaft coupling blew apart because previous owner didn't have an overrun clutch when connected to a brush hog that stopped abruptly ?
Tue, Dec 16, 2025 8:33 PM
Side-seat: I do not believe that this D2 had a PTO at any given time. The mention of an override clutch is a very good statement, as some folks have wanted to use their machines for pulling choppers, etc. there could be terrible damage without one. I might open it up and take a peek some more, as the presence of metal is disturbing. It steers and rolls without issue. So far it has been great as a parts machine. JM
Wed, Dec 17, 2025 2:52 PM
Z1939
Send a private message to Z1939
Unless I’m very mistaken, and I could be: shouldn’t there be pinion gear on the end of that shaft coming out into the case?
Thu, Dec 18, 2025 3:37 PM
Z1939
Or is that just a PTO shaft, and it looks higher because of the camera angle.
Thu, Dec 18, 2025 3:39 PM
Thank you received: 54
You're looking at the PTO shaft. The pinion is obscured by the crown wheel
Thu, Dec 18, 2025 8:45 PM
wimmera farmer
Thank you received: 7
Fish out the bits and you have a jigsaw puzzle to entertain yourself for Christmas.
Thu, Dec 18, 2025 9:17 PM
WF: I was thinking the same thing. Seeing how poor things can be, I can entertain myself for hours doing that. I might scrounge up a few dollars and buy an extension mirror and a light to look further inside. I am always intrigued by things broken, especially when it was not by me!
I might end up borrowing more parts from this hulk to do a cheap fix on another D2 that has sadly lost the ability to steer, thanks to swollen disks.
Fri, Dec 19, 2025 12:49 AM
Fri, Dec 19, 2025 12:51 AM
Those "swollen" discs in the steering clutches seem to be a very common issue with D2's. I have seen them so bad, a "hot wrench" was the only way to get the springs released and then often they would not separate. The old malady of the drums being so worn they would not come off the plates was another issue. - Have fun JM, keep you out of the doldrums of this tule fog and wet weather we have been having. - CTS
Fri, Dec 19, 2025 2:37 AM
