My Shipment from England has Arrived
Showing 1 to 10 of 14 results
Texasbest
Send a private message to Texasbest
Today I received a highly anticipated package with a few extra goodies in it.
#1 unit off the limited production line of the Big 15 / Little 20 Radiator support Part # V-62 cc, an 8C20 Patent Plate, Instruction Decal, 2 Caterpillar Decals and a Caterpillar Tractor Co. Decal.
Along with a few other goodies to wear and enjoy.
Have another box coming soon with a heatbox for this little 20 and some other items to be determined.
I also have an Intake and Exhaust manifold on it's way from Rosewood and will let everyone know how they all mate up together in the end.
Sorry about the pictures not cooperating with me. I tried rotating them.
[attachment=49060]Cat Goodies.jpg[/attachment][attachment=49059]Cat Goodies 2.jpg[/attachment][attachment=49058]IMG_1762.jpg[/attachment][attachment=49061]IMG_1756.jpg[/attachment]
Sat, Jun 2, 2018 7:25 AM
Thank you received: 77
Looking good Roby - only the "Best" for your baby : )
Sat, Jun 2, 2018 7:10 PM
Skinner
Thank you received: 38
Roby You must be happy today it’s like Christmas came early 😁
Sun, Jun 3, 2018 4:20 AM
hfdzl
Reply to Skinner:
Could you please enlighten me on the source of the castings ?
The rad mount comes from Brewser correct?
Sun, Jun 3, 2018 3:52 PM
Texasbest
Reply to hfdzl:
[attachment=49177]IMG_1800.jpg[/attachment][attachment=49178]IMG_1801.jpg[/attachment][attachment=49179]IMG_1672.jpg[/attachment]
Herb, Try Wally (Brewzer) for contact on these parts. He should be able to help you.
As you can see in the pictures I didn't have much left to work with on my original one.
I do have a repair piece that I got from Sandman years ago for my tailseat 15.
I need about 3 more years to get ready for the National show this October !
We are covered up at work and I'm worn out when I get home in the evenings.
Finally got my Wide Tailseat 22 blasted and painted on Memorial Day.
That was a bit of a moral boost. Need to get front idlers and tracks blasted and painted.
We've officially hit summer...
Mon, Jun 4, 2018 4:54 AM
hfdzl
Reply to Texasbest:
Nice nice nice !! Just struck me the R2 will look the same, but in OD green.
The heatbox and manifolds were sourced where ?
Mon, Jun 4, 2018 4:07 PM
Texasbest
Reply to hfdzl:
Herb,
I will have to double check in some of my books, but if I remember correctly your 5E series R2 (very few built) was similar or identical to the model 22.
Which is a different casting from this PV-15 / 8C-20 model. Mainly in the fact the governor doesn't run through the casting.
The later model R2's were similar to the J series D2 and they were beefier with Fins on them.
The Intake and Exhaust I sourced through Rosewood Machine and Tool in Ohio under Cat 15 parts, the heatbox you may touch base with Brewzer and see if he can hook you up.
I picked up this Little 20 off one of the Craiglist ads threads that chriscokid posted on here last year. It was up by Lubbock, Tx. Thanks Again, Erik !
Roby Whitehead
[attachment=49189]IMG_1715.jpg[/attachment][attachment=49190]IMG_1802.jpg[/attachment][attachment=49191]Little 20.jpg[/attachment]
Tue, Jun 5, 2018 6:22 AM
hfdzl
Reply to Texasbest:
Herb,
Roby Whitehead
I was looking for the Rosewood Machine info. The pic is very similar to about where I am in the reconstruction process.
Fabricating new track frames at this time. Here is the back half.
[attachment=49208]27 May 18 002.jpg[/attachment]
[attachment=49209]27 May 18 001.jpg[/attachment]
Not trying to hijack your post.
Tue, Jun 5, 2018 4:31 PM
Texasbest
Reply to hfdzl:
Herb, I like it! Much easier to work on these above ground level. My belly sure seems to get more in the way every year and it's a lot harder to get back up when you need something.
I'm not sure what I'm going to find inside the motor when I drop the pan. Motor was loose when I got it but there sure was a lot of slack in the crank pulley when I started looking closer.
Pulley was loose, crank key was really worn, popped the governor cover off and both weights were laying in the bottom of the timing cover... Governor gear has broken pin bosses, all of the balls were gone out of the governor follower bearing.
Water pump came off but the impeller was still in the block.
Got the head unbolted but it's being stubborn so far. Hopefully pop it off the next chance I get to work on it.
Just hope that there is no damage to the block itself. I have access to some parts engines.
This won't be an inexpensive restoration but hopefully it will turn out to be a good little tractor. Undercarriage is in darn good shape.
[attachment=49219]IMG_1747.jpg[/attachment][attachment=49220]IMG_1748.jpg[/attachment][attachment=49221]IMG_1753.jpg[/attachment][attachment=49222]IMG_1754.jpg[/attachment][attachment=49223]IMG_1752.jpg[/attachment]
Wed, Jun 6, 2018 10:36 AM
hfdzl
Reply to Texasbest:
Boy oh boy. Another tractor that got thrashed to an inch of its life. I started with 2, maybe got 1 I can put together.
The M2 wide, someone put a blade on it, and just thrashed it. Bent the pivot shaft, everything on the track frames had oversize bolts and welded together. Sprockets were junk, one final drive case was falling off held by 4 bolts on the bottom. Both engines already were .040 over, had one set of jugs bored and sleeved BACK to .040 over. Also fabbing up all new fenders and seatbox.
Like you say lot more work involved to bring the machine back but will be extra nice when done. I will continue to follow your progress with interest. Keep up the good work !
[attachment=49229]R2 case repair 001.jpg[/attachment]
repairing the final drive bolt holes.
[attachment=49230]R2 discovery 005.jpg[/attachment]
I have seen worse but not by much !
[attachment=49231]R2 discovery 013.jpg[/attachment]
case hanging on 4 bolts, 1 in gap on top.
Wed, Jun 6, 2018 4:21 PM
Texasbest
Reply to hfdzl:
Been travelling and getting a few things done. Went to the Golden Harvest Show in Colbert, OK on the 16th and met up with TomP and a few other members. Tom and I took turns running the 53 model D8.
Got a pretty good action picture of Tom pushing a pile up with it. I also saw a 1st edition Moving the Earth book for sale but it was quite a bit more than I wanted to spend after getting 4 other books there.
Looked around on Ebay and got a nearly perfect second edition shipped to me for less than $15 that just showed up today. 👍
The intake and exhaust manifold showed up from Rosewood and I am finalizing a few more items coming from across the pond for my heat-box to show up.
By the way I've seen some good interest in these radiator supports, if anybody else is interested in these or brass tags or some other items get in touch with Brewzer or I can help out.
I'll post some more pictures of the the little bit of progress I've made on some of my projects.
Roby Whitehead
Tue, Jun 26, 2018 8:13 AM
