My RD-6
your37m
Send a private message to your37m
need sleeves &pistons &head for it .wondering if old d-8 head will work?
Wed, Oct 15, 2008 6:00 PM
Can't tell you for sure whether it will work or not. Same bore and stroke but the part numbers for the RD6 heads and head gasket are different than the D8 part numbers for the same era.
Fri, Oct 17, 2008 8:29 AM
beaver-flat
Send a private message to beaver-flat
What's wrong with your old head?
Zimmerman in Iowa most likely has a RD6 head. I believe he also has the sleeve kits.
If not, Regal sells the sleeves, however they need some machining done before they can be used. Otto has the ring sets, and Olson gaskets can get head gasket.
Fri, Oct 17, 2008 10:30 PM
gwhdiesel75
Reply to beaver-flat:
Jim Zimmerman's phone number: 641-982-4207; FAX 641-982-4297.
Sat, Oct 18, 2008 12:13 AM
josh
Thank you received: 14
Reply to gwhdiesel75:
The RD6 heads, 3b3211 and 2b6480 cross directly to a variety of D13000 engines and indirectly to the 2u D8. so it should work, might need to switch some parts.
Sat, Oct 18, 2008 7:07 AM
brian18a
Thank you received: 70
Reply to josh:
The major thing one has to watch is whether heads have recessed valves or if they extend out of the face of the head. One has to have correct pistons to match head, so that valves do not hit piston.
Sat, Oct 18, 2008 9:14 AM
