My New Rooter - Is it a Le Tourneau?
Showing 1 to 10 of 38 results
David Wills Cat 60
I brought this 3 tine rooter this morning, generally it's in very good condition for it's age.
It looks like one of the smaller Le Tourneau rooters, can anyone confirm the manufacturer \ model?
I'm planning to take it along to the East Midlands Vintage weekend in early August for it's first outing.
1948 D6 9U
1963 D6B 44A
1970 951A 63K
1940's Le Tourneau S3 Rooter
Fri, May 22, 2009 6:48 PM
David Wills Cat 60
Sorry, picture size too large.
1948 D6 9U
1963 D6B 44A
1970 951A 63K
Fri, May 22, 2009 6:52 PM
OzDozer
Reply to David Wills Cat 60:
David - It looks very much like a Model 'S' LeTourneau rooter .. but the shanks or tines appear to have been modified, as all the pics and brochures I have of the Model 'S' show tines that are leaning back at a steep angle .. rather than the near-vertical tines of your rooter.
It's possible your unit was an early model with slight design differences to later models .. or a previous owner modified the tine angle.
The Model 'S' appears to have been produced from about 1938-39, and was dropped from the LeTourneau line by the end of WW2. It was designed to be pulled by tractors up to D7 (3T) size.
Fri, May 22, 2009 8:41 PM
David Wills Cat 60
Reply to OzDozer:
Oz,
Many thanks for the feedback.
I thought it looked like a Le Tourneau, as it's very well engineered piece of equipment, with all the additional diagonal bracing around the joints of the main structural members.
I think your right about the ripper tines, as all the other rooter pictures I have seen show the tines at an acute angle.
1948 D6 9U
1963 D6B 44A
1970 951A 63K
Fri, May 22, 2009 9:48 PM
David Wills Cat 60
Oz,
Oz,
Would it be possible to post a scan of the brochure for future reference?
Thanks, David
1948 D6 9U
1963 D6B 44A
1970 951A 63K
Sat, May 23, 2009 2:31 AM
Gordon.
Send a private message to Gordon.
Oz,
Thanks, David
Hi David,
That looks like Martyns yard (Fenland Tractors).
any way do you and Oz think that it maybe an Allied scarifer/ripper ?
Regards Gordon.
Sat, May 23, 2009 3:03 AM
David Wills Cat 60
Reply to Gordon.:
Hi David,
Regards Gordon.
I haven't heard of the name Allied before, do you have any more details on the company \ products produced?
1948 D6 9U
1963 D6B 44A
1970 951A 63K
Sun, May 24, 2009 4:03 AM
OzDozer
Gordon & David - I must admit I've never heard of Allied as a manufacturer of earthmoving equipment or attachments .. but having said that .. there would have been literally hundreds of small manufacturers who got into building items such as this, to turn a dollar (or a quid .. 😄 ).
The towed ripper is basically a simple device that many small companies built, because it can't be patented .. unless the builder invented some peculiar feature that was totally innovative, and which warranted a patent. I don't recall seeing any rippers that had any patent plates on them. Both the Cat and LeTourneau rippers (or rooters) were very similar in design.
In Australia, we had the Britstand Co (British Standard Machinery) building rippers and small attachments galore. Britstand also built scrapers, CCU's, blades, and other larger items such as graders, under licence from companies such as Oliver, Cletrac, Heil and Austin-Western. It's entirely possible this ripper may be a "Brand X", designed by any of the aforementioned companies and built by a small local manufacturer under licence.
However .. the overall design similarity to the LeTourneau leads me to believe it IS a LeTourneau, that has had the ripper tine angle modified. The wheel shape and diameter .. the cable mechanisms .. the angled braces, made from square bar, on corners .. are all good indicators of LeTourneau origin.
Here are scans of the back and front of the Model S Rooter spec sheet, dated 11/40 ..
Page 1 .. http://img200.imageshack.us/img200/8913/letrooters1.jpg
Page 2 .. http://img200.imageshack.us/img200/5508/letrooters2.jpg
Sun, May 24, 2009 8:35 AM
cr
Send a private message to cr
Reply to OzDozer:
There was a company called southwest ripper that made rippers very similar to Letourneau, but with the shanks were mounted much more vertically as pictured.
Sun, May 24, 2009 11:40 AM
D6 Pete
Reply to cr:
I havent seen a Le Torneau just like that one David, I think its just been altered ..post factory ! But i have been wrong before !!. Regards. Pete
Sun, May 24, 2009 2:30 PM
Gordon.
Reply to D6 Pete:
Allied Tractor Equipment Corporation.
Ateco as it's sometimes known were a division of the Young corporation of America they made towed rippers as well as direct mounted, logging arches. sraper boxes, land clearing blades etc etc. thought maybe land clearance blades maybe to be found in Austrailia Oz ? IH used their equipment alot.
I have found a picture of a towed ripper made by allied, although very similar it is not quite like davids. There was also another cable controlled make in the UK (D8 Size) i'm not sure of the name but i can picture the big green beast !!!
Regards Gordon.
Sun, May 24, 2009 5:22 PM
