Mule Drawn? or Tractor? Old Pull BIG Cat Grader
Showing 1 to 10 of 14 results
msrudecat
Send a private message to msrudecat
Wondering.....We have this Caterpillar Road Grader that I have not been able to find any brochures or pictures of one like it. Smaller ones, yes. Full Steel, a lot of gears and heavy wheels to turn. It is 28" across and to tip of tongue is 98". I found a serial number of sorts... 4A1651. I wondering if this was made during the depression and what powered it and what it was used for, perhaps the work WPA? I am impressed with the amount of knowledge on this site. We have over 200 antique tractors, but only this Cat Grader and an Old Cat Generator Power Plant. I wonder of the value of the grader also, if anyone would like to take a shot in the dark about that! Thanks for all your help in advance!
😖mash:msrudecat
Wed, Dec 29, 2010 3:56 AM
Tom Madden_archive
Tractor pulled. I don't have my serial number lists at work but this was NEVER designed to be pulled by anything other than a Cat. The big graders are typically priced against the value of scrap metal at the time. They are a great unit and are capable of doing lots of work if you have an operator on both the tractor and the grader that know what they are doing.
Wed, Dec 29, 2010 4:00 AM
chriscokid
Reply to Tom Madden_archive:
if my info is correct the 4A series is a Caterpillar Model 44 pull grader,
based on your serial # it is a hand control, single frame, wt 7100 lbs.
i think they made 1663 of them then upgraded to a double frame adding 90 lbs. to the weight starting with serial # 4A1664
Some one else here may be able to give more accurate info.
http://www.chriscomachinery.com/PullGraders.htm
Wed, Dec 29, 2010 4:40 AM
YeLLoIrOn
Send a private message to YeLLoIrOn
Reply to chriscokid:
The grader in the pic the msrudecat posted is a earlier double frame 44.
here is a pic of my later single frame.
Price wise i essentially gave $1500 for mine. Had to horse trade a 9ft 3-point angle blade to get it- its the only way he'd let go of the grader.
Wed, Dec 29, 2010 9:42 AM
KCB
Send a private message to KCB
Reply to YeLLoIrOn:
msrudecat: Your machine, 4A1651, is a "No. 44 Grader - Hand Controlled". It was manufactured in 1936, the last built of this series was 4A1925. The No. 44 frame upgrade started in 1937 with 8H serial number series.
Wed, Dec 29, 2010 11:13 AM
ruakina cat
Send a private message to ruakina cat
Reply to KCB:
I no nothing on your grader but would love to see a pic of the Generator Power Plant if you could one day thanks.
Wed, Dec 29, 2010 12:12 PM
msrudecat
Reply to ruakina cat:
OK...from the meeting of the minds here, what I think I have is a 1936 4A maybe double frame? That part I was confused about. And the serial number technicality. Does anyone think it was for the Work Program by the government or a private individual in 1936? Scrap price during the depression..... I searched many a farms out here in rural Oklahoma where they couldn't remember whether they scraped it in WWI or II. Ok. I can't figure that one out either! Does anyone have a brochure??
Also, here is the requested cat power plant picture....haven't even tried to figure it out, except a serial # 7P3231. Thanks for your interest in helping on that!
😖mash:msrudecat
Thu, Dec 30, 2010 4:27 AM
chriscokid
Reply to msrudecat:
it is my understanding that if the grader is made up of an open channel steel, then it is considered a single frame.
But if it is made up of closed channel steel or "box frame" then it is considered a double frame.
I may be wrong on this....
Thu, Dec 30, 2010 4:34 AM
Thank you received: 88
Hi, Chriscokid.
My understanding of the single-double frame story is different from yours. If you have another look at Msrudecat's photo, you can see that that grader has a frame rail coming from each side at the rear toward the front. These rails never actually meet but end on either side of a column at the front. The bottom end of the column carries the front axle mount. As I understand it, this is a double frame arrangement.
On single frame graders, the two frame members merge near the back of the machine to form a single beam, usually a box section, which then goes all the way to the front. In some cases, the single frame member may begin at a heavy cross member at the rear and just be a single beam from back to front, as in the Adams drawn grader in this photo.
Hope this helps.
Thu, Dec 30, 2010 5:59 AM
chriscokid
Hi, Chriscokid.
Hope this helps.
that makes sense but accordimg to his serial number it should be a single, or am i reading it wrong?
thanks for the explaination Deas.
Thu, Dec 30, 2010 6:16 AM
Sasquatch
Thank you received: 5
Reply to msrudecat:
[QUOTE=Also, here is the requested cat power plant picture....haven't even tried to figure it out, except a serial # 7P3231.[/QUOTE]
That powerplant is a D4400 engine, it's the same engine that powered the D4 tractors of the day.
Thu, Dec 30, 2010 8:16 AM
MSTEC STEAMFEST
