Motorized elevating grader
Hobo groh
Send a private message to Hobo groh
So I found this when I was working on a 3D printed grader sorry upside down
Tue, Feb 26, 2019 6:41 AM
Thank you received: 34
Hi, Hobo Groh.
That is a Domor side elevator attachment on a Cat 12 grader, common back in the 1950s and '60s. From the orientation of your photos - ah supp - that machine might have been here in DowNunda. LOL
Tue, Feb 26, 2019 7:19 AM
Hobo groh
Hi, Hobo Groh.
You think it would work on a diesel no 10 if it is possible to find one
Wed, Feb 27, 2019 7:53 AM
Reply to Hobo groh:
Hi, Hobo Groh.
I don't know. I have never had the chance to inspect one close up but I suspect that the drive for the elevator comes from the power shaft under the cab, the same one that drives the grader controls, and I would not be surprised if there was a special drive box to fit to the end of the power shaft and the bottom of the vertical column to allow that drive to be extended to the elevating grader.
Then there is the question of whether or not the number 10 would be heavy enough to carry that weight out to the side like that. I suspect that it would carry it but I don't think I'd want to be side cutting too many slopes with that side downhill.
I think that pretty much any short, light belt conveyor would do the same thing if you could mount it and get a drive to it. It would be neat to have the original but a home-made one would be neat as well.
Wed, Feb 27, 2019 8:05 AM
D4Jim
Thank you received: 12
Hi, Hobo Groh.
Says I have to add 10 characters!!
Cats Forever
Wed, Feb 27, 2019 10:35 AM
Wombat
Donor
Reply to D4Jim:
The Drive comes from the rear end of the grader, if you look closely at the photo you will see the drive box on the back.
Wombat
Wed, Feb 27, 2019 11:00 AM
oldbeek
Reply to Wombat:
Wombat
will it raise high enough to load a truck? What would it be good for? Several passes could create ditch and move the dirt to build a berm.
Wed, Feb 27, 2019 11:30 AM
D4Jim
Reply to oldbeek:
The county used a rig like this up until about 1975 for elevating our dirt roads. Since then they hung about 2 tons on the rear of the grader and used the standard blade to elevate the roads. They also used them for building terraces but also used many pull type elevators and pulled with a large farm tractor.
Cats Forever
Wed, Feb 27, 2019 11:42 AM
STEPHEN
Reply to Wombat:
Wombat
[quote="Wombat"]The Drive comes from the rear end of the grader, if you look closely at the photo you will see the drive box on the back.
Wombat[/quote]
Yes, live engine power. Morse Silent Chain? Rpm too high for roller chain. Or some idler gears in there.
Wed, Feb 27, 2019 12:41 PM
