Motor Grader No. 12, 99E newby questions
Showing 1 to 9 of 9 results
Bernard
Send a private message to Bernard
I just bought my first Caterpillar. A 12E, s/n 99E12344. It has the hydraulic system for multiple controls and electric start. Attached is a photo of it as it arrived on an RGN trailer. A few dumb questions:
1. Are you supposed to use the circle as tiedown points? I have the service and operation manuals, but they don't give the tiedown points. And I can't offhand find any tiedown points. (Not that I plan to ever transport it again.)
2. What year was it made?
3. How do I order parts?
4. Is that an OEM rops? It has no front pillars.
5. The hydraulics don't work, but visually, it all looks intact on the outside. The prior owner said (and take this with a grain of salt) that they worked after he filled the hydraulic tank, but then quit. He thought the fluid leaked, but there's no sign of any leak. I pulled the hydraulic filter and it's clean as a whistle. So my plan is to fill, vent the air, and see what happens. Any thoughts?
 [attachment=70842]IMG-3506 ps.jpg[/attachment]
Mon, Jan 23, 2023 3:06 AM
Thank you received: 111
Hi, Bernard.
Looks like a nice catch, at least from the outside. Nope, there were no dedicated tie-down points on those old girls. I suspect that the ones made for the military had tie-down points but I would not put money on it,
I would not rely on the circle to hold it. Personally, I would chain to the front axle front support arch pulling forward and to the tandem cases pulling back.
There are likely others here who will know better.
A couple of pages that might be helpful to you:
https://www.acmoc.org/library - if you are a member.
8th post down on this page:
https://www.acmoc.org/bb/discussion-d72/11465-home-at-last#91423
Mon, Jan 23, 2023 5:09 AM
bruce oz
Thank you received: 22
Hi, Bernard.
12E, s/n 99E12344 built 1965
Mon, Jan 23, 2023 10:05 AM
Bernard
Reply to bruce oz:
Thank you Deas Plant and Bruce Oz. I do have the service and operation manuals and have submitted scans to the library. (Although the same or similar publications are already in the ACMOC library, my scans are better. I've been digitizing books for many, many years.) The photos in the service manual were really well done. The lighting and staging were immaculate, and you can see that they were shot in medium or large format, not 35mm. The care and money it took to produce these manuals, and especially the photos, is a remarkable achievement. I recently digitized a Case manual from the 1990s and the photo and print quality is nowhere near as good.
And I've typeset Deas Plant's instructions, attached.
Mon, Jan 23, 2023 10:23 AM
Reply to Bernard:
Hi, Bernard.
If my understanding 'kee-wrecked', Cat parts manuals have a LONNNNGGGGG history. I have been told that when Benjamin Holt sold his first tracked tractor, #111, to a sugar farm in Florida, he sent a a 'parts book' with it. This 'parts book' had photos of EVERY part of the machine from ALL the angles necessary to be able to show ALL the dimensions of each part so that the new owners could fabricate parts for themselves 'coz there weren't any overnight air services back then.
Thank you for the digitized version of my 'rantings'.
Mon, Jan 23, 2023 12:20 PM
gauntjoh
Librarian
Thank you received: 5
Hi, Bernard.
Bernard,
Thank you so much for providing the new scans of the OMI and Service manuals for the 99E No12 grader which I have now added to the library replacing the previous inferior copies.
Mon, Jan 23, 2023 5:03 PM
Thank you received: 52
Reply to gauntjoh:
Bernard,
the hydraulics not working being due to trapped air is possible. a sign of this is the pump being very noisy and cavitating so it will make a humming /buzzing noise as you cycle the system and as the air clears it should reduce. to bleed each function you want to full stroke each item each way one at a time have a helper keep topping the tank keeping it above the minimum line. but not full as you need to allow the air out or you can suddenly get a big glug of air and oil goes every where as it over flows the tank.
NOTE this is only general advice on bleeding hydraulic systems. the service manual for the hydraulics will have the correct procedure.
and as deas said you chain the axles down nowhere else and yes you lower the blade and rippers if its on the ground it cant move a coupe of bits of dunnage(timber) between the cutting edge and the trailer deck saves the deck and helps keep the blade still particularly on steel decked trailers.
dont chain the blade circle as away to hold it down its only made to carry the blade and the forces as the blade is working. not hold the machine on a trailer. these old girls didnt have dedicated chain down points no machinery did back then. people were expected to just know how to do it and use common sense before all the oh&s laws and requirements came in and this stuff was thought of.
a rough rule works with all wheeled machinery if you chain the wheels/axles down you will have pretty well held on. and is sufficient load restraint provided your lashing equipment is suitably rated for the load mass.
Mon, Jan 23, 2023 6:19 PM
Reply to trainzkid88:
parts are ordered via the part numbers and model and serial number prefix. get a parts book if you have got one there are separate parts books for the machine itself and the attachments so the rippers if fitted might be a separate book.
many parts can still be had via the global dealers network if you have a part number to give the parts interpreter. you can also use parts.cat.com
note some older ones need to be converted by adding a few zeros after the prefix example 4a213 would become 4a0213 to make it a six character number.
most bearings and seals are available after market as cat used off the shelf ones mainly from hyatt and timken. and chicago rawhide seals.
companies like ITR and berco do a range of cutting edges and parts. tillys crawler parts in toowoomba QLD have aftermarket, second hand and reco parts and you never know what they have. there are a few old cat wreckers in america too. google is your friend.
Mon, Jan 23, 2023 6:34 PM
Deebo
Librarian
Thank you received: 75
12E specs sheet now in the Technical Library thanks to Brian scanning his!
 [attachment=70851]64BF88F6-A84D-40D3-BD77-A390D44526A7.png[/attachment]
Tue, Jan 24, 2023 1:32 AM
Bernard
Good news. I added 5 gallons of Chevron 1000 THF and now the power steering works! And I can't find any leaks other than from my sloppy filling technique.
Now I'll do some more reading to figure out the rest of the hydraulics such as side shift.
Wed, Jan 25, 2023 9:19 AM
