motor clean out
motor clean out
earthworm
Send a private message to earthworm
did a in frame on my 343 and it time to clean out cooling system so what the best to use cascad lye or some parts house stuff thanks ross
Fri, Feb 2, 2007 8:34 AM
SJ
Send a private message to SJ
Cat sells a cleaner for the cooling system & is 4C-4610 for qt. size & 4C-4611 the gal. size. You,ll have to see what size you need for your rad. capacity which probably is on the cleaner container & other instructions for using it too.
Fri, Feb 2, 2007 11:22 PM
