More newbie questions on my D2 5U
putsplut
Send a private message to putsplut
Hopefully none of you get tired of my questions. I'd hate to destroy a good machine out of ignorance.
My D2 has serial number 5U 1265. The operators manual states that I need to lubricate the steering clutches every 10 hours. Since I'm before 5U12520, I should have some oil cups for this purpose, but either they don't exist or I don't know where to look (or both!). At the base of my steering clutch levers, I see 3 grease zerks; one by each lever and one in the center directly behind the gear selector. I think these are the bearings for the clutch levers and lubricated every 20 hours. Underneath my seat I see two more grease zerks. If one of these locations is the right spot, I guess I assume that they have been upgraded?
My cat didn't come with a volume compressor. I've seen button adapters available to be able to use standard grease guns. If I'm gentle with a regular grease gun, is that acceptable or should I be trying to find a volume compressor?
Wed, Jan 7, 2009 9:26 AM
the Farmer3
Send a private message to the Farmer3
The steering clutch oilers are the ones back under the seat and they must have been changed to grease fittings.
Wed, Jan 7, 2009 10:00 AM
Sasquatch
Thank you received: 5
Reply to the Farmer3:
The button head adapters are usually best serviced with a volume compressor, a grease gun may easily blow out the track roller seals without you even being able to feel it. Recommended roller lube is a 00 grease, I've only been able to find it in one gallon to five gallon pails because it's more like sticky oil than grease, but they might put it tubes too, I don't know. When using the volume pump I can feel when the rollers get full, but still need to be careful.
Wed, Jan 7, 2009 10:30 AM
putsplut
Reply to Sasquatch:
Thanks for the responses. Short term, I'll be borrowing a volume pump from a co-worker who owns a 1937 D4.
After a quick internet search, it seems people are pretty proud of their volume pumps. I think I'll be doing some asking around locally before I shell out $300-$400 for a new pump. 😮 Not lubing enough machines to justify that.
Wed, Jan 7, 2009 12:12 PM
chugwater crawlers
Reply to putsplut:
You can get John Deere corn head grease in tubes for a grease gun. It will work instead of buying a drum or pail of 00 grease. Hope this helps.
Wed, Jan 7, 2009 11:49 PM
| Kingaroy, Queensland
