More D2 questions
More D2 questions
catsteve
Send a private message to catsteve
Hello everybody. I am continuing to put the D2 back together this afternoon and have had a few successes.
I have now encountered a small problem that i hope the good acmoc folk can help with.
Could someone please advise if there is a gasket to go between the bell-housing and the main block. or if this is to be bolted straight metal on metal. I have a dry clutch will replace the water seal that was leaking in there.
If there is a gasket could someone also advise the part number.
Thanks in advance. The questions might come thick and fast over the next day or so.
steve
Thu, Mar 8, 2012 2:26 PM
Thank you received: 93
Hi Steve,
the faces bolt up mtal to metal. Be sure to lightly draw file the faces to remove rust, dirt, burrs etc. Check the threads for integrity. Re-coil/heli-coil any suspect ones.
Also the faces should be oil free for best clamping friction. Lightly oil or grease the bolt threads for future removal.
Thu, Mar 8, 2012 3:20 PM
catsteve
Reply to edb:
Hi Steve,
Thanks for the fast response edb.
regards
Thu, Mar 8, 2012 4:02 PM
