More D2 issues
More D2 issues
lil d2
Send a private message to lil d2
😕I was cutting in some trails yesterday with the D2.Did about 7 hours work when I lost power to move.It seemed the rpms dropped and it stopped in its tracks.I let it sit for a while and fired it back up,the rpms are up but it won't move unless you pull back and hold the clutch lever and at a snails pace.I pulled the plate to adjust the clutch.I pulled the adjustment pin out which is sitting approximately 1/2 way in the row of holes,but couldn't get it to budge to the next hole.I am thinking it's just and adjustment with the clutch,Your thoughts are greatly appreciated.
Thanks,Mark
Wed, Apr 14, 2010 7:24 AM
cojhl2
[quote="lil d2"]😕I was cutting in some trails yesterday with the D2.Did about 7 hours work when I lost power to move.It seemed the rpms dropped and it stopped in its tracks.I let it sit for a while and fired it back up,the rpms are up but it won't move unless you pull back and hold the clutch lever and at a snails pace.I pulled the plate to adjust the clutch.I pulled the adjustment pin out which is sitting approximately 1/2 way in the row of holes,but couldn't get it to budge to the next hole.I am thinking it's just and adjustment with the clutch,Your thoughts are greatly appreciated.
Thanks,Mark[/quote]
Looks like two opposite issues!! Is the final analysis that the engine is ok and it's the clutch? Or,,, is the clutch bound up against the housing somehow?
Strange it would be Ok for 7hrs then all of a sudden have a clutch prob that you did not notice creeping up on you. This is going to be an interesting thread.
Wed, Apr 14, 2010 10:19 AM
lil d2
Reply to cojhl2:
Thanks,Mark[/quote]
[quote="cojhl2"]Looks like two opposite issues!! Is the final analysis that the engine is ok and it's the clutch? Or,,, is the clutch bound up against the housing somehow?
Strange it would be Ok for 7hrs then all of a sudden have a clutch prob that you did not notice creeping up on you. This is going to be an interesting thread.[/quote]
It definately has me stumped.I took the plate off above the clutch.The clutch spins when not engaged and does move forward when engaged.I have been wanting to adjust the clutch for some time but cannot get the pin the move to the next hole.The clutch lever does have play but still snaps into the engaged position.
Wed, Apr 14, 2010 10:54 AM
bruce oz
Thank you received: 19
Reply to lil d2:
hello lil d2 ,you could end play in the big end ,maybe it floating back jamming the clutch .try the end play at the front pulley ,see if it will move out towards the rad .bruce oz
Wed, Apr 14, 2010 11:17 AM
bcwayne
Reply to lil d2:
Perhaps it sheared the fiber clutch disk teeth where they engage the flywheel ???
