Money Pit Ten gets some newer technology
Showing 1 to 7 of 7 results
1935farmall
Send a private message to 1935farmall
I decided not to use the felt oil seal on the crankshaft pulley here is what I came up with. It only took 1/2 an hour with my lathe but not having oil leaks is priceless
Sun, Oct 14, 2012 4:13 AM
Cysco
I have been working on my Ten as well and noticed an oil leak at the front pulley. I thought it was a regular seal but now I know different. What is the seal number you used.
Thanks......Bill
Sun, Oct 14, 2012 6:55 AM
Thank you received: 77
Reply to Cysco:
Thanks......Bill
How does one size the ID of the seal, given the shaft size or vice versa? The shaft is slightly larger OD than the seal ID - but is there a rule of thumb or does the seal manufacturer state the shaft size that his seal fits?
Neil.
Sun, Oct 14, 2012 7:19 AM
1935farmall
Neil.
I actually used a magneto drive seal for a farmall cub. The seal will need to be cut down in thickness from the 1/2" that it comes to 1/4" which is the more difficult of the machining. I found that after removing the extra metal it fits the casting loosely so I put it in with some locktite. Then I plan on putting a small amount of silicone before putting on the metal cover plate and I think that it will be secure that way. If you have a good auto parts store they should be able to find a seal with the exact sizes needed to fit the opening without altering it. I just used what I had. Once I fit the seal I turned down the pulley to 2.162" and polished it. I will let everyone know how it works when I am finished.
Sun, Oct 14, 2012 8:02 AM
chriscokid
Reply to 1935farmall:
I would recomend putting a seal sleeve on the pulley before installing the seal, it will save the pulley and help the seal last longer.
I think SKF calls them speedy sleeves, they can be ordered in just about any size.
I will post a pic if needed on monday.
I just put one on some final drive parts and for a 2.5" dia part the sleeve was about $35.00
Sun, Oct 14, 2012 8:15 AM
Neil.
[quote="Neil"]How does one size the ID of the seal, given the shaft size or vice versa? The shaft is slightly larger OD than the seal ID - but is there a rule of thumb or does the seal manufacturer state the shaft size that his seal fits?
Neil.[/quote]
seal catalog is usually arranged by nominal shaft size and then lists alternate OD, width, style and material. Most have a recommended housing diameter (seal OD less a thousandth or so for a secure fit)
the repair sleeves mentioned here increase the shaft diameter slightly, but the manufacturer usually recommends the same seal with or without the sleeve.
With the liminted number of hours one of these old CAT's will ever see, I would save the speedy sleeve $ for some other part of the project. If it ever wears a groove, someone in the next generation can install one.
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare timeπŸ˜„
Sun, Oct 14, 2012 10:09 AM
ol Grump
Neil.[/quote]
One of the handier books out in my shop is an older CR Seal handbook that I scored at the "local" NAPA store a few years ago. It lists (I think) all the seals that they made up to that point. Now when I need a seal, that's the book I get out first. It gives the outside, inside and thickness by bore size and shaft size plus what the actual sealing material is.
Sure beats trying to pry an old seal out while trying to preserve the numbers on 'em πŸ˜†
The other book I get into quite often is the old SKF bearing book I acquired at the same time. Same format, ID, OD and width for both ball bearings and roller bearings plus in the case of ball bearings whether they're sealed, shielded or open types.
Sun, Oct 14, 2012 8:52 PM
zootownjeepguy
Reply to ol Grump:
McMaster Carr is a good source for Seals and Bearings too, although they don't list as many selections as an industrial bearing/power transmission supplier.
www.mcmaster.com
McMaster is also an excellent source for gasket material, rubber moldings, fasteners, cutting tools (drills, taps), hoses, tubing, etc., etc.πŸ‘πŸ‘
Rich Salvaggio
D2 5U9917
Sun, Oct 14, 2012 9:50 PM
