Model 44 hydraulic unit question
Showing 1 to 10 of 36 results
jdierking
Send a private message to jdierking
I've got a job coming up where we are replacing the rudder steering hydraulics on a river tug boat. They currently use two Cat model 44 hydraulic units #8w5820 coupled to 10hp electric motors. They have the double valves, one controls the back rudder, one controls the front. They only use one unit at a time and have the other as backup. I was online looking for information on these old units and I can't come up with what they were originally off of. I found that the D2 used a 25gpm unit and the tag on these says 9gpm. Anybody ever seen a 9gpm model 44?
Kinda crazy to see something so old still in everyday service. I want to look into when the boat was built to see if they were put on new or if they had a previous life on a machine somewhere.
Tue, Feb 10, 2015 4:38 AM
On tractor applications they generally came with 25 and 37gpm pumps.
Never have heard of flow as low as 9 gpm. They do use "Vickers" pump cartridges so they may of had one with that flow option.
Tue, Feb 10, 2015 5:40 AM
jdierking
I'm curious if Cat supplied these units for special applications like this, or if they were ordered out of the parts book, or if they were taken off an old machine. If there are no machine applications with a 9gpm pump, I guess maybe Cat supplied them. The boat has cat engines and gen sets too. I'm supposed to go look at it this week. I'll have to poke around a little bit.
Tue, Feb 10, 2015 6:39 AM
josh
Thank you received: 14
Reply to jdierking:
Can you post a picture of the tag on the #44 unit ?
Tue, Feb 10, 2015 8:02 AM
Thank you received: 77
Reply to josh:
Get lots of pictures, particularly of tags and general arrangements
Tue, Feb 10, 2015 9:44 AM
CATCURT
Send a private message to CATCURT
What is the name of the boat, I have seen the same set up on a boat.
Tue, Feb 10, 2015 10:33 AM
jdierking
Reply to CATCURT:
I'll get some pictures. I'm not sure what the name of the boat is, I haven't seen it yet. It's in Hermann MO now.
Tue, Feb 10, 2015 11:45 AM
BillWalter
Reply to jdierking:
I used to see tow boats set up like that in Louisana back in 1958. That seemed to be the standard steer set up back then. The boat in Hermann must be that old. What engines does it have?? Bill Walter ,Parkville, MO.
Tue, Feb 10, 2015 9:27 PM
jdierking
Reply to BillWalter:
All I have is the hydraulic unit info right now. I'll try to post some pictures when I go look at it this week. Interesting that this is a "common" set up, but I guess if Cat was supplying the engines it makes sense. I don't know the age of the boat yet, It's being rebuilt now, so I know its been around a while.
Tue, Feb 10, 2015 11:47 PM
CATCURT
Reply to jdierking:
Is it the Hermann Sand and Gravels boat?
Wed, Feb 11, 2015 7:00 AM
jdierking
Reply to CATCURT:
Yes it is.
Wed, Feb 11, 2015 11:06 AM
