Model 12 7T clutch question
SpragueM
Pulled the engine on the grader today. Needed to replace the pony starter engagement shaft. Discovered what we believe to be a thrust washer of sorts. As I do not have the correct parts diagram could someone post a scan of the clutch assembly? Or does anyone know the part number of the part in the center photo?
Serial number 7T189 ,maybe the same as the 9K series.
Regards,
Matt
Mon, Jun 20, 2011 8:56 AM
I don't have the 7T/9K manuals but in the 8T1-up which I am pretty sure is the same you have a damaged pilot bearing race which is held in by the three capscrews. Originally an "L" shape, race with flange. Part number is a 4B8107
Mon, Jun 20, 2011 10:38 AM
